Carolina Jeeper
- Rollie
- Jan 19, 2021
- North Carolina
- 2019 Mojito! Jeep Wrangler Unlimited Rubicon
- Occupation
- Electronics Technician at R. J. Reynolds
I have had this kit sitting in my garage for a while and just hadn't had time to install or couldn't take my Jeep out if Service. I even got the Full River AGM batteries.
Anyway had time today and I took way longer to install since I inspected all that hard to see/reach stuff while I had the opportunity. Tightened ground strap from firewall to engine. Looked for leaks and found none. Verified those locks are engaged on those plugs that many of us are unaware of. Basically a pretty thorough visual check.
Install was not bad, but removal was a bit more tricky. I have a winch so I had to deal with that wiring during removal and installation.
After install I double checked all connections I touched and even the factory ones including Genesis ones. Very impressed by the Genesis wiring.
Ok here's my personal observations on design and where I think there is just a little room for improvement.
1. There should be some vertical bolts in the bottom that will clamp this tray down better near the front just like the factory tray. I'm going to modify this tray to have these later.
2. One of the two horizontal bolts that bolt the tray in near the front outer edge are too long and should be shortened. (See attached photo). If the battery moves over from vibration and bumps, the bolt is likely to puncture the battery casing. Easy fix, but just a heads up.
My ESS had stopped working back in mid November and is now working again!.
Battery voltage is 14.5V at idle and no faults or any signs of oddities.
That's all I have on it right now.
Edit: So to be clear, the shorter bolts that are described and shown in the install video were missing from my kit. Of course I didn't think much of it and just wanted to point out that if anyone else has the same issue to be aware and correct this by trimming off the factory bolts or use some shorter bolts if you already have some.
