Let me see your front bumper.
Gio
Gio
MN
24 Willys XR 2.0,
I have a factory steel bumper and like the fact it is a two in one. take off the ends for wheeling. with a WARN winch plate install, the bumper is reinforced at the frame rails with heavy duty brackets and can be flat towed. The WARN winch plate kit goes beyond just the need in installing a winch. It's heavier and has more components than the completion for good reason.
I installed mine having the controller box in a remote location. it makes the bumper clean looking.
That's pretty much what I want ours to look like, although I may try the Badland winch.
Did you order the cross bar on the top or did the bumper already have it?
I should have had the dealership throw one on before we got the rig.
shooting4625
Colin
Utah
Coming soon 2023 2door wrangler Rubicon
Rockhard 4x4, aluminum, more than strong enough for regular off road, only 6lbs heavier than the stock plastic, also they use the best powder coating instead of that textured crap ever other brand uses
Looks like new every time you clean it
Takes stock fog lights,
Fully adjustable to allow room for winch
Jeep Wrangler JL Let me see your front bumper. imag
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
I assume my 2019 Rubicon was a fully optioned order sent to the dealer. Some are destined for show room. The original owner got it mid 2022 with only 20 miles on it. It is a factory bar and probably was a dealer addon.. no mention on original windows sticker nor on the build sheet.
Oletimer
Darrell
Crystal River, Florida
23 ram 1500 5.7 , 24 392 final edition , 26 F150 tremor 5.0
retired Logging Contractor
On my '22 392 I have this aluminum stubby from Next Venture Motorsports. It is a stout winch mount with a superlight aluminum skin over the top. It doesn't work with the factory fog lights, but they make a mount for fog lights behind the skid plate that work well with the Baja Design fogs I have mounted there.
On my other Jeep, a '23 JT Mojave, I have this Motobilt Crusher Series stubby bumper. It has no provisions for the stock fog lights.
On my other, other Jeep, a '25 JLR, I have this bumper. It works well with the stock fog lights.
I love the 392s look !
pfletcher229648
Patrick
Orlando
2022 JLUR XR w/SOT, 2024 JLUR X w/SOT(On Order)
CIO
Rival 4x4 USA full width steal bumper with bull bar and recovery points.
I have a 2022 JLUR XR w/35s and a SOT top. Let me say I’m about the furthest thing from a mechanic that someone can get. Just didn’t get that gene from the long line of mechanically inclined ancestors in my family. I did get the software developer gene, so it worked out for me.
Ordered the full width stamped steel for the JL. Even though the instructions are mediocre the install isn't that difficult except for pieces not lining up. Pieces not lining up exactly probably doubled the time and effort and creativeness needed to install the bumper. The original fog lamps did fit, with a bit of adjustment.
The fit and finish of the bumper and other parts right out of the box had some noticeable damage, but after having the bumper on for just a month it's already showing chips in the finish and rust. I was very careful in handling the parts during installation. I laid a blanket down on the ground so that the bumper would not get scratched while being installed. The bull bar right out of the box already has paint bubbling and I would expect that it will start peeling in a couple of weeks.
If I was grading, I'd give overall look and design an A, Fit/Alignment a C, Finish a B-, and Instructions a D.
I will say I reported this to Rival and they stood behind everything. They sent me, for free, the spray paint to touch up the bumper. I had also ordered their steal front lower skid plate, without me even asking, the refunded the full price of the skid plate and sent it to me no charge. Honestly couldn’t have asked for a better response from a manufacturer. I would buy it all again from them.
The bumper and bull bar have plenty of space and holes predrilled for lights and light bars and anything else I could want to put on it.
I had purchased a Badlands Apex winch, but it was just too thick to fit in the cutout for the winch. The Apex is a big boy. Not wanting to cut on and take a grinder to my new bumper, I’m not that good with power tools. I ended up putting it on my wife’s 2024 JLUR X that came with the mopar steel bumper. I’m searching for a slightly thinner yet capable winch for my Wrangler.
That’s it. Good luck on you bumper search.
Jeep Wrangler JL Let me see your front bumper. IMG_1028
Jeep Wrangler JL Let me see your front bumper. IMG_1029
Wkaz
MA
2021 Sahara
Ironman 4x4 is nice stuff and it actually has a crash test rating. Rigid fog's wired to factory fog light switch( had to change connector) Auxiliary lights, wired to aux switch as well as compressor. Never needed a winch but always need air.
Jeep Wrangler JL Let me see your front bumper. 20240120_1543011
Jeep Wrangler JL Let me see your front bumper. 20240210_120344
Jeep Wrangler JL Let me see your front bumper. 20240407_134305
Medsker
Jon
South Jordan, Utah
Retired Engineer
I really liked my Rival 4x4 aluminum bumper. It looks good and is well built. I had one on my Jeep that burned up and the only reason I don't have one on my new Jeep is that it came with the factory winch. If I could sell the stock winch and bumper for enough money to do the Rival bumper and a Torrix winch I would.
Before:
Jeep Wrangler JL Let me see your front bumper. 20240517_090349
And after :)
Jeep Wrangler JL Let me see your front bumper. 20240618_104901
ArcadeTracks
PJ
Pittsburgh, PA, USA
Nice that you can get a cover on the winch. My cutout doesn't give me enough clearance.
It's very tight, and doesn't go down in front of the grille, but it stays put. My guy did an amazing job getting everything to fit without cutting the grille.
Rubi6mt
Nj
2021 JLUR 6mt
I actually like the factory steel bumper with the end caps removed.
Works great and takes hits on the rocks pretty well.
Here's my 2024 392 after a bit of an adventure
Jeep Wrangler JL Let me see your front bumper. Screenshot_20250427-203303_Gallery
beachbumm78
Kristy
Phoenix, AZ
2020 bikini blue Rubicon
Athletic trainer & Massage therapist
Next Venture - raw aluminum, coated with shark hide. Winch tray and recovery hooks are zinc coated.
I always love how clean and simple this one looks. This is on my list for whenever I decide to change out bumpers.
