LED Installation Causing errors (saving you the pain)
aeonixx1001
Kim
Arizona
2020 Jeep JL
I recently installed all LED lights on my JL. I got an error the first time I drove, (Right rear tail light out). I pressed on the brake and turned the blinker on and the error went away. The more I drove it the error increased. Then it started throwing "tail lights out and Right Turn signal out". I went in and researched this (for about 3 minutes) and found that there is a work around for this "Known" (wtf, I didn't know about it) issue. and that is to put a small but mighty 6 Ohm 50 watt resistor in series with the light (easy) You tube it you need to. This prevents the Computer from seeing a lower power which typically indicates the light is out and puts enough load on the circuit to prevent the error, it also prevent "hyper flashing".
I guess my real bitch is: Why do you let people find out the hard way. It should say right on the package "may require additional equipment to function correctly". I think I am just pissed cause I am soldering wires in my garage and its 106 degrees, I think I have Heat Hatred. Oh and dont mount that resistor to anything of any value. 50watts gets hot fast, it will leave a blister...
RBesse3333
Bob
Clermont, Florida
2019 Wrangler Unlimited Sahara
You should get a Tazer device that allows you to change the light settings to LED. I did that to mine and it worked great. You could go to your dealer and have them change it but it may be costly.
aeonixx1001
aeonixx1001
Kim
Arizona
2020 Jeep JL
I actually have a Tazer. I took it out after I replaced my 3rd set (2) of Batteries in one year. I was not aware that you "MUST" do a complete reboot after making a change, otherwise the control system stays on and drains your battery. Now I know what caused the issue I may put it back in..
jludave
The Isle of Long
IT Manager
