LCA torquing when doing lift
Willywhitie24
NOVA
2024 4door Willys
Will torquing the LCA while still in the air without the weight of the vehicle on the ground cause lift? I just installed lift suspension and its supposed to lift 2-2.5" but ended up with 3.5" lift, the back is 2". Im thinking of loosening the bolts and re torque it. My jeep looks sag in the back. I didnt do the install a shop did.
jadmt
jeff
montana
no it won't cause lift but it will cause bind. absolutely put it on the ground under its weight loosen everything and rock it side to side a few times and them retorque..if you need more room run it up on some ramps...
Jeep Wrangler JL LCA torquing when doing lift tempImagefktjG6
Terrymo
Terry
2023 JLURXR 3.6 ET
The lift height won’t change, but if you know it was torqued while on the lift, take it back and make them do it correctly.
Willywhitie24
NOVA
2024 4door Willys
Well im not sure if it was torqued while on the lift. Im just trying to find whats causing the extra lift.
Roky
Roky
What brand lift ? Most companies base there advertised lift height on the Rubicon, so it’s not unusual that some other trims will see a little more lift…..
Willywhitie24
NOVA
2024 4door Willys
I have a 24 willys 4 dr and i put 392 FE take off. One member here did same but got 2.5 " front.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
I got a little over 4 inch or so lift from my 2.5 inch up front, little over 3 inch at the rear. May be it will settle over time?
6th Floor Mule
Keith
Woodstock, GA
2018 JLU Sahara 6MT
Maybe the difference of a std 392 vs. 392XR vs. 392XR with a winch, etc.? I imagine that would result in a ~1.5” delta on a non-392 swap.
azjl#3
North AZ
Tell them torque at ride height
