KIWI Master 9" JL LED LIghts
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
@Arterius2 ... For Model 1, since the DRL "cross" is an integral part of the low and high beams, they must be wired to be always on, right? For example, to an Aux switch (ignition/latching) or Fuse 57.
For Models 2 and 3, the DRL halos could be wired later. Am I thinking about this correctly?
Nah, the image isn’t shown correctly, they should all be wired the same way, the DRL separately.
blnewt
New Mexico
Just ask @cosine he knows!
Yeah, the fact they show the cross DRL lit up just by itself confirms it's a separate circuit :)
JSFoster75
Bluff City, TN
Here's an update on my Wireless Switch solution...
I bought the Trigger 6 Shooter combo kit for JL/JLU here: https://www.morris4x4center.com/trigger-6-shooter-combo-kit-jl-jt.html
Use Code: DEC30 for $30 off of $300 or more (Not sure when it expires?)
Install was smooth, directions are here:
I wired mine in so I didn't have to worry about changing out batteries.
interesting note on these, when I installed the app on my phone, I realized I could turn my auxiliary lights into strobe lights using my phone… I can turn them all on or off independently and/or independently into strobe lights.
This would’ve come in really handy a couple of nights ago when we stopped to help someone that had had a wreck.
Stolar13
Łukasz
Poland
Wrangler Sport S 3,6 - 2dr
Anybody install the 7" lamps with adapter to 9" from ALiexpress? How it looks?
blnewt
New Mexico
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
Amazon, not AliExpress, I was sure to buy a set with rubber rings to fill the gap, I also added spacers to close the gap :like:, Pro Comp 7” LEDs.
Jeep Wrangler JL KIWI Master 9" JL LED LIghts EBEE751F-2D96-4996-A8DA-418EF750F898
Jeep Wrangler JL KIWI Master 9" JL LED LIghts B66A62EE-CADE-4A68-A06C-A8442EF6A494
1/2” spacers
Jeep Wrangler JL KIWI Master 9" JL LED LIghts E496C52A-C036-4ED8-9070-B2618867CCE0
ElvisJL
Greg
Dallas
2018 JLU Sport S
Those that have been running the KIWI Master lights for several months, have you had any issues since installing over the past few months? Any problems with moisture, lights dimming, cutting out? I was looking at the Oracle lights but I'll be honest, the KIWI is much more affordable.
El Zilcho
Max
San Diego
2018 JLU Sport, Rubicon axles
I have them for about 4 month, no problems at all so far.
Chipe
Chip
CT
Silverado
I have had no issues whatsoever. Running at least 4 months now.
JSFoster75
Bluff City, TN
I have been running them for approximately four months with no problems.
Spearmin
Eric
NY
JLU
I have had them for about 4 months also. 0 issues, unless you consider the occasional flashing from on coming traffic (which if I aim then lower I am sure that will go away as well.) Great lights very brite.
ElvisJL
Greg
Dallas
2018 JLU Sport S
Awesome to hear fellas. I'm going to get a set ordered and installed. Do they have their own bulbs installed or do I need to get a set of bulbs as well?
JSFoster75
Bluff City, TN
The LED's are a sealed system, there are no bulbs to install or replace. :)
Fmrock164
SWFL
2018 JLU Sahara
For those that installed these kiwi, what are you doing for fog lights?
