Jumperless Aux Battery Bypass
Sturtzy
Wesley Chapel, FL
2019 Wrangler Unlimited Sport
If you have an aux battery, yes.
Yes, pull fuse F42 and disconnect the aux cable from the main negative terminal. It should be the skinnier of the 2 cables connected to the terminal.
Sturtzy
Wesley Chapel, FL
Which cable is for the aux. Battery?
Jeep Wrangler JL Jumperless Aux Battery Bypass Screenshot_20230528-144225_Facebook
Sturtzy
Wesley Chapel, FL
Viewing on smartphone ... hard for me to see diameters. What year is your JL?
2019.
I unhooked the left one and here's what it did
2 tries with start button then started
Power steering light came on
Traction controll light on
And 1 other light maybe for suspension?
Auto start light on still??
andy29847
Andy
Trenton, SC
2020 JLUR
MY 2020 - aux cable disconnected and tied back
Jeep Wrangler JL Jumperless Aux Battery Bypass i-84VRVN3-X3
I'm wondering about the condition of your main battery. I haven't read all of your post so I do not know what brought you to this thread.
JOMOjl
Corey
2020 Jeep Wrangler Sport
Machinist
Really hoping I don’t jinx myself but here goes.
I removed my aux battery about a month ago. I went in through the top because I didn’t want to mess with the fender liner. Plus I was going to have to pull the positive lead up anyway.
Disconnected both leads, taped off the negative, reassembled the fuse box, and added the positive lead from the aux to the main. Battery was near 3 years old so I got a bigger battery to replace the main. Tazer keeps my ESS off. No problems. Shows 14 on the dash.
Sturtzy
Wesley Chapel, FL
I just got the jeep a couple weeks ago and its been fine. The battery is an Interstate. I need to get my main battery tested and start from there I think. Gauge on dash says 14.1 v at idle.
Sturtzy
Wesley Chapel, FL
Battery tested good.
Ormond Beach, Florida
Retired at 55 ..
2019.
On your 2019, the smaller diameter, Aux negative cable is the cable closest to you on the Main's negative terminal when you lean over and reach in over the passenger side fender.
Did you pull Fuse F42 ?
Sturtzy
Wesley Chapel, FL
Yes
I'm going to try it again. I'll let you know what happens. Thanks for the help!
andy29847
Andy
Trenton, SC
2020 JLUR
Battery tested good can be a trap. Our Jeeps seem to go funky when the battery gets around 12.4v. 12.4 is a good test for most batteries (50-70% life). With the aux negative unhooked, and after the Jeep has been sitting for a couple of hours, set it to run without starting it (on my Jeep, with the proximity key, I press the start button without putting my foot on the brake. The first press should go to aux, the second should go to run). Check the voltage display on your dash voltmeter. Answer back with your findings.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Resting voltage can be OK when it's tested in isolation. What you may consider doing is observing the battery's voltage when cranking the engine. Knowing the latter number when there's a load demand on the battery will provide the necessary context about its actual health.
Sturtzy
Wesley Chapel, FL
Removed fuse and cable again and here's the results
No others on this time.
Voltage on dash reads 13.9
Put fuse/cable back and drove about an hour. Voltage at 13.4 (which I know is low)
Auto s/s light on. Don't have a meter to double check voltage. Will have a meter tomorrow to check more. Thanks again
