Jscan drl control on radio.
Lucky7Wrangler
NWFL
2025 Wrangler Sport
I playing around with my Jscan on my 2025 Sport. Ive figured out how to activate drls. How do you, if you can, have the drls turned on/off in the Uconnect? Does it have to be under the Canadian setting or what does it need to be set as?
Lucky7Wrangler
Lucky7Wrangler
NWFL
2025 Wrangler Sport
Nm I figured it out. Set the drl to Canadian and it appears in my safety settings. Disabled the seatbelt chime and the start/stop.
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
When dealing with the DRL's, yes... set to Canadian...
Here is an adaptation for you...
Turn Signals for DRL's:
ADAPTATION ---> DRL--> Day time running lights Configuration- Canada DRL
ADAPTATION
---> DRL - Day time running lights - settings --> DRL Lamp Location --> Turn Signal DRL
3arl0fBruce
Rob
Northern VA
'23 Wrangler JLUR MT - Earl
You disabled the start/stop? With JScan? I was under the impression that's not possible. Can you please list the adaptation that you used?
Lucky7Wrangler
Lucky7Wrangler
NWFL
2025 Wrangler Sport
I was under the impression you couldnt by reading older posts. I turned off the hood switch setting and the star/stop setting to off. First stop I came to the engine stayed running. I drove around for a little and no start/stop. The light on the dash button is not on either and nothing shows on the instrument cluster. I havent left the house yet today but when I leave later I hope its still deactivated.
Lucky7Wrangler
Lucky7Wrangler
NWFL
2025 Wrangler Sport
Well nm. Stop/start still activates.
Pape
Quebec
JLU Sahara
If i remember properly you need to also unplug the hood switch for disabling start stop. Wate jscan does it stoping light in the dash from the action
