JLUR decelerating while coasting in **2H**... help?
BernJLUR
BernJLUR
Bern
Bradenton FL
2019 Ocean Blue JLUR (on order), 2015 Anvil JKU, 1995 4.0L YJ
I think your issue is two fold. First could be the steep gearing of the 8 speed auto and 4.10’s. Secondly, it’s possible that you are having the surging idle issue which is extremely noticeable during deceleration at those speeds. There is a TSB that addresses the surging as well as the noisy cooling fan. Have you noticed an abnormally loud engine cooling fan noise while at idle with the AC turned all the way to its coldest and highest fan speed setting?
Hi Shenanigans. I read threads about people complaining about the cooling fan at coldest. Mine is louder than my previous JKs for sure, but the comments I read about other drivers commenting about its noise or describing it as a jet liner going overhead, that doesn’t fit. It’s louder than last generation, but not ridiculously like some had to fight through. I wonder if it’s your first fold scenario plus my inexperience above 3.XX gearing.
BernJLUR
BernJLUR
Bern
Bradenton FL
Btw I might have missed this part, but are you driving 4H on pavement?
Shoot! Dumb response. Meant 2H. Yes. Typical daily driver mode. Tested 4H and 4L at dealer and worked, then back to 2H. Sorry - that must’ve been confusing.
Rubicon4Life
Long Island, New York
2019 Jeep Wrangler Unlimited Rubicon - White
Hi all. I’ve had three automatic JK/Us and I drive countless rental vehicles each year. I just purchased my 2019 factory build JLUR three weeks ago. Shortly after leaving the lot, I noticed the brakes felt a little bit sticky and grabby (technical mechanic terms ) at under 20 mph coming to a stop. Shortly later, I realized that the vehicle seems to decelerate even when coasting at that speed without touching the brake pedal. It kind of feels like when cruise control slows you down when you’re a few mph over the designated speed, or like driving with two feet where the left foot is always gently and inconsistently riding the brake. It’s subtle, but it’s constant and I’ve never experienced it with any other Wrangler or rental.
I’ve searched the forums and found nothing. But I don’t even know what terms to search for. I’m hoping my fellow Jeepers can guide me a bit so I don’t sound like a lunatic when I consult with my dealership. This is not a Jeep thing. I’ve been in Jeep things since 2010 (1992 if you count a CJ7 manual). This is a my brand new JLUR thing.
Any ideas? Thanks in advance for your guidance!
I have a 2019 Rubicon that I picked up at the end of May with the 3.6. I feel the exact same thing. Not sure if its a problem or just the way this vehicle is designed. I came from a 2011 Sahara Unlimited that was a complete POS. I'm interested to see what other 2019 Rubicon owners with the 3.6 say. Ironically enough my vehicle is in the shop right now for a replacement front grill and my soft top rattling. I didn't even think to bring this issue up because I assumed it was normal. Have you heard anything else?
COSJL
Colorado Springs
2015 WK2, 2019 JLR?
I don't know if I have the same symptoms as OP, but at slow speeds I do feel what I assumed was too much engine braking. Sometimes the transmission shifts a bit rough 4-3-2 as well. These two combined can make for an unpleasant driving in stop and go situations. I'm hoping the shifts improve with miles.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
there is a TCM update to be flashed at the dealers to make the shifting a bit smoother as well.
#4Jeep 1st Wrangler
mark
north olmsted ohio
In got the same shifting. It is a normal condition with this transmission. Low speeds, it will downshift and feels like it's holding the vehicle back. I'm still in the auto repair business, every one I've driven does this....JL models
(8 speed transmission , common with 4.10 gears etc....) I assume that you have a Rubicon or Moab with the higher gets gear ratio?
COSJL
Colorado Springs
2015 WK2, 2019 JLR?
Thanks you. Any chance there is a TSB/update number that I can tell the dealer? I am assuming they will just say mine has latest software.
COSJL
Colorado Springs
2015 WK2, 2019 JLR?
Thanks for the input. You are right, I am not hoping the engine braking to change - nature of the beast I guess. I do have a Rubi. I do want to smooth out the transmission shifting though.
Arterius2
Jerry
Vancouver, BC
Arrowhead
George
Stillwater, NY
2018 Wrangler JL Sport
This ^^^^^
It's totally normal, no need for service, no diagnostics required, your brakes are fine. Most cars tend to freewheel when you let off the gas but they programmed the 8spd a little different. I actually lets you control your speed with the throttle pedal kind of like a manual.
Durango
Central California
2020 Jeep Wrangler Rubicon Unlimited, 2019 Ram 1500 Quadcab 4X4, 2018 Challenger Hellcat, 2018 Charger SRT, 2018 American Dream, 2017 Ram 1500 Reg Cab 4X4, 2020 Redwood 3951MB, 2019 Mercedes 4WD Van
Every 7 or 8 or more speed tranny FCA vehicle I've owned in the past couple years does this - I've just assumed it was part of getting better mileage somehow, or? Regardless, it's handy when driving in the mountains to have the tranny downshift without having to consciously do so.
BernJLUR
BernJLUR
Bern
Bradenton FL
Yes. JLU Rubicon with the 4.10 gears. This is good and bad. Good that it's a normal thing. Bad that I don't like the driveability coming to stop signs and lights and traffic jams.
Rubicon4Life
This is great info and definitely clears things up for me. I have a 2019 Rubicon that I purchased in May of 2019, 2 months ago.
JeepCares
Auburn Hills, MI
JL
Hey BernJLUR,
If you do decide to move forward with visiting your dealer in regard to this concern, please feel free to send us a private message. We would be more than happy to have your concerns formally documented as well as provide you with an additional layer of assistance by connecting you with a Case Specialist who can work alongside your dealer.
Jeep Social Care Specialist
WXman
Central Kentucky
Yes, the trans. and engine braking is WAYYYYYY too aggressive for a vehicle of this type. For what it's worth, my JT Gladiator is the same way. It's extremely annoying.
Also, if you accelerate hard from a stop, say, 80% throttle, and then quickly go to 40% throttle, it'll hang up in the gear it was in and the RPMs will keep screaming. It won't upshift. VERY annoying.
As usual, FCA has a way of taking world-class ZF transmissions and ruining them with in-house programming.
