JLU Aux switches
Paulguy100
Wisconsin
2021 JLU Rubicon
I was too cheap to get the OEM Aux switches. Is there a good alternative or should I bite the bullet and get Mopars?
dblankenbaker
Scottsdale, AZ
Lots of old Jeeps. JLURD ordered 5/7.
Sidspider
Ted
New Jersey
1986 CJ7, 2021 JLU Willys
An sPod is around $600 with everything, so $400 sounds good if it includes everything you need. There are definitely cheaper options depending on how much work you want to do and how clean of an install you want.
Paulguy100
Paulguy100
Wisconsin
2021 JLU Rubicon
Just looking for an inexpensive switch that looks decent. Any photos?
Daffydnbugs
Illinois
2020 JL Wrangler RUBICON
The Voswitch JL300 works great, gives you 6 switches installed of the factory 4. Installs in blank spot on center column below climate controls.
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
At Risk Ute
Christian
‘23 392 XR
Retired Navy
I've been eying these. Do they tie into the existing infotainment system, or provide any signaling to the CANBUS like the Mopar switches? What radios work with the passthrough jack?
Red side ties into the CANBUS and unsure what radios work with the phone jack thingy.
I just went with the black side for a Rubicon. Easy install / looks stock.
Jeep Wrangler JL JLU Aux switches 7D4DC9B4-BF4B-4C41-95CA-85DE6EB7618F
GrayWolf.Overland
Subash
I went with the full kit and this is what it looks like installed on a Sahara.
The red side left switches for the locker are CANBUS controlled, so they will work only in 4LO
the Aux A and Aux B on the red side operate like normal switches.
I have my front and rear ARB lockers wired up to the locker switches and the compressor is on Aux A. Rest of the switches are just there.. until the time I find ways to sink more money into my Jeep :)
Jeep Wrangler JL JLU Aux switches 1647765801004
INCRHULK
Lance
Canada
litwphoto.com
Are the switches programable? Can you set them for latching/power on with ignition, etc?
GrayWolf.Overland
Subash
Per the user guide - no. These are as simple as wirings at the other end of the fuse box to connect to whatever you want the switch to turn on and off. The locker switches has a safety features using the CANBUS passthrough so that ppl don't turn on the lockers accidentally when not in 4LO
