Aux switches
mbccenter
Forest Lake, Mn
2021 Wrangler JLU Rubicon
I hooked up a rearview camera to Aux switch 3. Worked good for about a week but now none of
the Aux switches show power. They are still configurable in Uconnect but no help.. Any ideas?
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
How did you connect it? They are separately fused, so it shouldn’t be that.
mbccenter
Forest Lake, Mn
Connected to Aux 3. The indicator lights on the switches don't even come on.
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 991 911 / 2013 E92 M3
...huh?
There's not much to go on... were they factory-installed, or installed afterwards? Are the other switches being used?
mwilk012
Oklahoma
Service
Check power at fuse F98, 10A power supply to the switch bank.
How did you ground the camera?
You’re going to have to be more specific here. How exactly did you connect a rear view camera to aux 3? Which connection? How did you run a wire to the rear?
mbccenter
Forest Lake, Mn
I'll check F98. Wolfbox head is on the mirror where the power wire runs to passenger footwell.
mwilk012
Oklahoma
Service
When you start the jeep does it say “battery charging auxiliary switches unavailable”?
melendez69
Marc
Waxhaw NC
...huh?
Look factory. Other switches are not used.
I'm not sure what 'look factory' means.
Have you researched similar threads ?
This one seems to resemble your problem a bit. You mention it "starts & runs fine" but that doesn't necessarily mean your batteries are in tip-top shape.
