JL spied tow testing
WXman
Central Kentucky
2018 Wrangler Unlimited
Most trailer axles are 3,500 lb. capacity. So you then subtract the weight of the trailer itself and it's likely that the load inside the trailer is less than 2,000 lbs. So, a very very small load and look at that thing squat! This is why Wranglers have low tow ratings...a convertible with high COG and flexy springs, plus the hitch only bolted to a crossmember rather than down two frame rails.
I'm not even sure why they are doing this testing. A Toyota Corolla could handle that just fine.
Spank
The trailer can handle 1,800lbs, sure, but the trailer empty is already at 900. That's about half the towing capacity of the current JK. The shape and size of the JL just isn't going to make it an effective towing vehicle, regardless of the new powertrain.
Vegas_Sirk
Boise, ID
2013 JKU
When you compare these to the new JT its such a huge difference. If towing is something you want the JT is looking like the better rig.
The Great Grape Ape
Canadian Rockies
2015 JKU AspenX 5spd , 2015 JK Sport 6spd
There's too much tongue weight on the JL hitch. That would make for squirrelly handling at highway speed.
Maybe this is an "Off Label" ( unsanctioned) use of the Test Mule ? Test driver's use ?
It was likely a sanctioned internal test as they were testing the JT at the same time, with the JT getting the dual-axle trailer treatment and other setups.
As they are in a big parking lot, it could be prepping setups in extreme situations for feedback before actual testing. In addition to tongue weight added rear payload could account for that squat too.
However, replicating more weight by imbalancing the load still doesn't replicate things like inertia, etc so definitely artificial... which matches the artificial test 'road'.
zgn
Maryland
Wrangler TJ (2001)
Is it just me or does the rear window seem really long relative to the JK? May just be an illusion. JK window is fairly long as well.
Demonic
Austin
MA
I heard from a reliable source the trailers were empty.
Kidding.
