Jeeps with hard top
Carolina Jeeper
Rollie
North Carolina
2019 Mojito! Jeep Wrangler Unlimited Rubicon
Electronics Technician at R. J. Reynolds
I would love to be able to hang my top in the garage but I am not sure the ceiling will support it. Previous owner put up a plywood ceiling and insulated which is nice BUT it’s poorly supported. Basically the ceiling is a 16 foot span with zero support and maybe 2x6 boards
Some of the support in a garage ceiling is from the roof trusses. Or at least they are in the ones I've seen built. If those 2×6's are on 16" center then your ceiling is pretty strong. It should've been built to hold up a garage door on an overhead track and they are heavier than the hard top by quite a bit. Maybe take a look up there and see what's really holding up that ceiling.
Austin23
Austin, TX
2020 Jeep Wrangler Rubicon
This ^^^^^^^^
Second this^^^^^^. Eyebolts screwed into the ceiling joists and 4 ratchet straps does the trick.
As an extra measure, I use 12 inch pool noodles at the 4 points where the straps contact the hardtop for an extra level of protection.
Deleted member 74991
Guest
Hi All. I am trying to figure out the best solution for taking off my hard top and storage in the garage. Please share how you store yours. Pics if you have them!! Thanks!
You and a Friend. Put it in a spot in the garage it won’t get in the way. Saves $$$ unless you have to pay them in Pizza and Beer.
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
I went with the Harken Hoister. I have enough height to lift the top completely up and out of the way for both my Jeep and the wife’s BMW. Given the shelf at the rear of my garage the top lift wasn’t really an option, and the hoist system allows me to easily lift or lower the top
Jeep Wrangler JL Jeeps with hard top 47DDDDCD-5EA9-4D89-BB38-9B4891EB580A
Jeep Wrangler JL Jeeps with hard top C651AA00-E9EA-4A6A-90E5-680D7CE84D1A
Valpo Jeep
Doug
Valparaiso IN
My enclosed ceiling was added. My original construction was a truss across the roof at the ridge to support the center. I have 2x6 rafter boards that go from the ridge to the Eve. All that should be solid. When they enclosed the ceiling they added boards that run from the Eve over to truss along the horizontal but never tied anything in mid span to the roof, I’ll have to stick my head up there again but I am not even sure they used 2x6. I have a loft storage shelf along the back of the garage that the 1 corner was hung off the roof from. With the weight on the loft it and the ceiling deflected several inches there. I put in a 4x4 and used my floor Jack to lift it back to level and square.
I am sure that carpenters built my house to begin with but all the add ins later were done by the court jester.
Industrialwrench
San Diego
08 SRT Challenger. 18 4Runner off-road premium.
I bought 4 carpenters horses and just set the top on them in the back yard. Cost me $60? They are high enough off the ground I can squat under the top and pick it up easily. I take the top on and off by just lifting it from a center point and walking out the back of the Jeep with it balanced over my head. I always have the rear seat out when I do this.
Sgt Beavis
Rick and Miyako
Wrangler JL Unlimited Sport S
The Man, The Myth, The Legend. In my own mind.
There’sOnlyOne
Greg
NW Georgia
2021 JLUR
Carolina Jeeper
Rollie
North Carolina
Thats unfortunate. I've seen the work of the court jester so I understand your predicament lol. At some point one of them was playing electrician in my house.
Murphydog
Seattle
Me too, clearly worked on both wiring and plumbing in my house, basically ripped it all out and started from scratch…
Slate
Kentucky
'̶9̶̶7̶̶ ̶W̶̶r̶̶a̶̶n̶̶g̶̶l̶̶e̶̶r̶̶ ̶S̶̶p̶̶o̶̶r̶̶t̶̶, '21 Willy's, '23 Rubi 4XE
Gen 2 Hoist-a-Cart. By far one of the easiest solutions to pulling a hardtop with one person and storing it and two doors - especially if you don't want to use your ceiling. Allows you to have a spidershade or any other sun shade installed and have no issue popping the top in minutes.
https://www.extremeterrain.com/lange-gen2-hoist-a-cart-jl-014-gen2.html
It seems like the reviews are all over the place on this. I could us something like this for my '23, which I don't have yet of course. I have a shelf, but it already has the hard top to my '97 TJ and I don't really have the ceiling space. Something like this would seem to fit my needs better.
Aside from what you already mentioned, do you have any other feedback on this? How often do you use it to take the hard top on and off? Honestly in my case, I would probably use it twice a year, after winter to put the Soft on and before winter to put the Hard back on. The other devices seem more appropriate for someone who either doesn't have a softop or is constantly taking the hardtop off and on - and those devices seem to excel at that.
lowmpg
Ryan
Kent Island, Maryland
2021 Rubicon, 2025 Ram Limited
I've used it probably 10 times. Never a single issue ever. Once you have the straps setup correctly it's easy on easy off. Personally I didn't want the whole ceiling deal and since I have a spidershade on, some of the other 'top removers' required that shade wasn't there. Plus this setup worked great even with my 2.5" lift and 35" tires
PLaz
Laz
Omaha, NE
Jeep Wrangler
I went with an electric hoist from harbor freight. And installed it in the ceiling. I basically followed Roadrash's youtube video.
I love that color. Is that stingray?
Malifestro
Richard
Portland, Or.
2021 Wrangler 4xe
TopLiftPro + ARC wall hangers is the best solution IMHO…
Which mudflaps are those? I like how there is no gap in the front!
I've had those extensions on order for 4+ months. Have 3 of 4.
