Jeep's website and quick order packages....
dwp
boston
2021 Wrangler Rubi 2 Door
I freely admit i may not be the most tech savvy here.... but going through jeeps website and building some wranglers for comparison, 2 door willys standard tranny... it lists 3 packages as options? Convenience Group, Tech and Safety.....
is that accurate? no trailer tow group anymore?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Receiver hitch shows as standard equipment, but make sure you verify everything with your dealer (see spreadsheet in my sig) before ordering. The site is notoriously wrong.
  • Like
Reactions: dwp
dwp
boston
appreciate the quick reply... just annoying.
the build/price only shows those three groups (Conv/tech/safety) but when i do an inventory search the closet to the build also has the 24W quick order packaged listed (with the receiver and wiring harness and other junk) for an additional $7,500.... which i cant seem to find on the Build site....
thank you.
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
Keep in mind that the jeep.com builder isn't for building & ordering a Jeep. It's geared for searching existing stock on dealer lots. There are pretty much always discrepancies between the Jeep.com builder and what can be ordered and built today. Only your dealer has the current accurate information.
Halxen
Patrick
'24 Wrangler JLURX
thank you.
The build site is absolutely broken right now. I'd have to double check, however, I don't think the 24W customer preferred package actually has the hitch. If it lists "Trailer tow prep package" that is just the 4 & 7 pin wire harness. Since around mid January what was previously the Tow package was essentially spilt into 2 separate pieces. The "trailer tow prep package" and the ADH package which is the aux switches and receiver hitch. I'm not positive on the Willy's but I think it is the same package but on the Willy's it is about $1100 vs the Rubicon $95 because the Rubicon wire loom has the aux switch wiring already included in it where as the standard Willy's does not so when you're ordering it for that trim they are essentially swapping out the Willy's wire loom for the Rubicon wire loom to pre-wire for the aux switches.
12psi just recently updated the order sheet thread with some new sheets from April or May IIRC so definitely double check it on there.
EDIT: I just double checked the April '24 order sheet from 12psi's thread and it does look like the Willy's trim still lists coming with both the Aux switches and the receiver hitch. He only posted the 4-door sheet so no idea if that is the same for the 2-door.
