redracer
- Robert
- Aug 22, 2017
- Manteca, CA
- 2023 4xe Rubicon
I wrote up my first attempt at a python can display. This one is just a text console display using curses. I'm display battery voltage, X Y Z from 0B2 , and RPM and speed data. It works!
I'm calling this simply pycan.py
you will need python3 and the python-can library. To install the library use:
pip3 install python-can
Updated. I fixed the data overwrite issues and added some can cleanup on termination.
Code:
#!/usr/bin/python3
# jeep canbus live data display
# import libraries
import can
import curses
# start curses screen management
stdscr = curses.initscr()
# lay out our plain text
stdscr.addstr(1,1,'Batt')
stdscr.addstr(1,11,'Vdc')
stdscr.addstr(3,1,'Roll')
stdscr.addstr(3,14,'Tilt')
stdscr.addstr(3,26,'Yaw')
stdscr.addstr(5,1,'RPM')
stdscr.addstr(5,14,'MPH')
stdscr.addstr(7,1,'Steering Angle')
stdscr.addstr(7,25,'Torque')
# update the screen with the text
stdscr.refresh()
# startup the canbus interface and filter only the ids that we want
bus = can.interface.Bus('', bustype='socketcan',filter=[{"can_id": 0x2C2, "can_mask": 0xFFF},{"can_id": 0x02B, "can_mask": 0xFFF},{"can_id": 0x322, "can_mask": 0xFFF},{"can_id": 0x023, "can_mask": 0xFFF}])
# wrap everything in a try to catch exceptions cleanly
try:
# iterate through all messages received
for msg in bus:
# match a can id and can bus
if msg.arbitration_id == 0x2C2 and msg.channel == 'can0':
# place data using str to convert float data to a string
# this is using the 3rd hex word, deviding by 10
stdscr.addstr(1,6,'%-5s' % str(msg.data[2] / 10))
# once the message has been processes, refresh the screen with the data
stdscr.refresh()
# match another message
if msg.arbitration_id == 0x02B and msg.channel == 'can1':
# place data, multiple words each in its own spot
stdscr.addstr(3,6,'%-6s' % str(((msg.data[0]<<8) + msg.data[1] - 2048) / 10))
stdscr.addstr(3,20,'%-6s' % str(((msg.data[2]<<8) + msg.data[3] - 2032) / 10))
stdscr.addstr(3,30,'%-6s' % str(((msg.data[4]<<8) + msg.data[5] - 2048) / 10))
stdscr.refresh()
if msg.arbitration_id == 0x322 and msg.channel == 'can0':
rpmstr = str(((msg.data[0]<<8) + msg.data[1]))
if rpmstr == "65535":
rpmstr = str(0)
stdscr.addstr(5,6,'%-6s' % rpmstr)
stdscr.addstr(5,20,'%-6s' % str(((msg.data[2]<<8) + msg.data[3]) / 200))
stdscr.refresh()
if msg.arbitration_id == 0x023 and msg.channel == 'can1':
stdscr.addstr(7,15,'%-6s' % str((((msg.data[0]<<8) + msg.data[1]) - 4096) * .5 ))
stdscr.addstr(7,32,'%-6s' % str((msg.data[2]<<8) + msg.data[3]))
stdscr.refresh()
# catch errors, display them, and exit cleanly
except:
bus.shutdown()
curses.nocbreak()
stdscr.keypad(0)
curses.echo()
curses.endwin()
raise
