InspiredEngineering
When the JL was first released and FCA posted pics of the Sport models, we noticed something missing, LED headlights to be exact. We couldn't believe Jeep would release another Wrangler model with anemic sub-par headlights. We also saw this was a great opportunity to create another JL upgrade.
We started work on the headlights back when we designed the fog light replacement kits, back in June. We have been working non stop since then to release a kit.
We decided to design adaptor brackets in house to run our existing Halo or EVO II headlights. This helps simplify the install and offer you guys multiple lighting options.
Each kit includes:
While we know the bulk of this market will be Non LED package equipped Jeeps, these are still an upgrade to the LED package kits. Based on our testing both models are stronger than the OEM LED. We will be posting pictures soon.
Needless to say, these are a HUGE upgrade over the OEM Halogen lights.
Here is some info on the Halo models
" LightWorx 7" Round headlights are designed from the ground up to give people what they want. A great looking light, which works far better than stock, at a very reasonable price.
While trying to find the perfect blend of form and function, Lightworx hit a home run. These lights meet DOT standards, so you will have no issues running these on the street. These are designed with an innovative Daytime running light which lights up the Halo around the light with a bright white color. They also change color to Amber, which is a great replacement for turn signals, to supplement them, or just to change the pace and look cool.
Light is utilized with the use of two projectors one for the low beam, and one for the high beam. This allows for a very crisp light cutoff, and takes full advantage of the light produced.
Light color is 6000k which is a fine white, and matches most OEM cars."
Check out the pics, we will have mounted pics in the next few days. We were just too excited to finally let the cat out of the bag.
Find More info and pics here.
Each kit includes:
- A pair of headlights (of your choice)
- Wiring adaptors ( no need to cut, splice, or remove the wiring from your stocks)
- Headlight brackets (assembled in the headlights)
- Additional wiring and connectors needed
