Inspired Engineering Prismatic Series LED Lights
Status
Not open for further replies.
InspiredEngineering
Sam
Miami
2018 Rubicon JL, 2013 JKU on 60's, 1997 TJ on D60s
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4491
All New For 2018 Next Generation Prismatic LED Bars
When we first introduced the Prismatic Series LED bars they were instantly an industry standard, focusing on design and technological upgrades. We are constantly working to improve our products and come out with something ground breaking. The All new next gen Prismatic LED bars are just that.
Our Prismatic Series LED bars operate just like a normal LED bar, but give you the option of changing your backlight to any color you choose. These use RGB technology, which means the LEDs have the power to change to any color you desire at the touch of your finger.
These are not only limited to RGB color changing for the show circuit, they have real life applications as well. You could use a white backlight, or an amber one to act as a roof marker light, rather than having to drill holes in your truck roof. Other features include being able to use the back light and light bar simultaneously, strobe features of the back lights, color change, and even change to music.
Color changing isn’t your thing? That’s fine, if you choose not to opt for the optional Blue Tooth control module they will operate just like a traditional light bar, with industry leading light output, mated to a very sleek and stealth look with our all new Black Series reflectors and low-profile design. These light bars are less than 2.5” deep, resulting in less wind noise than before, eliminating that annoying whining you get with other brand lights.
When it came time to choose an LED to produce the light, we went over to our friends at OSRAM. We are using the latest in LED technology to offer you a brighter light while using less power than before.
All new Blue Tooth power module! Still waterproof, now includes its own wire harness which allows you to control the RGB back lighting independent of the light bar, or while the light bar is on. It also powers up to four Prismatic lights, it could be four CUBE lights, or 4 50” bars, or any combination, saving you money since you no longer need one for each light, and you can control each light simultaneously. If you already have a module, you do not need to buy one for your new light.
Our Prismatic Series LED CUBEs operate just like a normal CUBEs, but give you the option of changing your backlight to any color you choose. These use RGB technology, which means the LEDs have the power to change to any color you desire at the touch of your finger.
You asked for more diverse mounting options, and we have answered. These lights have two mounting locations, the traditional side post, and our all new MMS. Modular mounting system means that you no longer must worry about making brackets or buying a certain light bar to fit the pre-made holes on your bumper. The lights have a track on the bottom which the mount slides into, allowing you to pick your perfect spot while keeping the light low key and stealth.
If you prefer the traditional side mounting brackets, please mention that whilst ordering and we will substitute them at no additional charge.
We have also updated our Reflectors, to offer a more modern look, while increasing efficiency by 28% while updating our Pressure equalization breather to make these lights even more water resistant than before, earning a IP69K rating. It is safe to say, these are the best light bars on the market, while still being affordable!
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4481
You can see the NEW Reflectors here
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4081_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4131_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4121_1024x1024
Breather
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4161_1024x1024
MMS Mounting System
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4181_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4191_1024x1024
Back Light
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights fog-light-oem-plugandplay-halo-offroad-light-4261_5eeeb76b-684a-4186-ae3e-6b0f40e79d0d_1024x1
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights fog-light-oem-plugandplay-halo-offroad-light-4281_48403c49-65c0-4e83-b0c9-11ee25f41e51_1024x1
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights fog-light-oem-plugandplay-halo-offroad-light-4291_8b026366-5bc7-4b74-bb1c-b08a07dde234_1024x1
Available in 14", 20", and 50".
More Details and Pictures can be found here!
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4331_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4431_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4411_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4361_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4351_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4371_1024x1024
Jeep Wrangler JL Inspired Engineering Prismatic Series LED Lights jeep-led-fog-light-oem-plugandplay-halo-offroad-light-4461_1024x1024
Status
