Remorseless
- May 10, 2022
- NC
- '22 JLR 2.0T, '24 JTR, '19 Charger R/T
- Build Thread
- Link
- Occupation
- Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Guy Who Defines What A Jeep Guy Is
Are the PUG cams failing with the rollers still intact? My thought has always been it's cheap roller bearings failing and collapsing and then wiping out the cams, and that the rollers that are going are just in a less-well-oiled spot in the valvetrain. Couple that with Jeep struggling to get all the casting sand out of the engines over the years and cheap bearings getting gummed up in a spot where oiling isn't amazing, and that's a pretty plausible way for the cam to get wiped out.One of these days I'd like to get a hold of one of the failed cams to do some testing on it. I'm curious as to how deep the heat treating penetrates, and how hard the lobes are. I think that there is a good possibility that it's a combination of ill effects that wipe them out with improper treatment of the cam itself, and poor lubrication. If cams are coming from more than one supplier, or if there is variation of the alloys, and heat treating process that would help explain the difference in why some fail faster than others.
