Installed WARN Power Interrupt Kit - A few notes
Kleiss1
Gary
Arizona
2021 JLURD 2018 Mustang GT 6-sp.
Looks good. I just did that and I am running it off aux 3 and mounted the driving lights relay to the bracket as well.
Is Aux. 3 the 40 amp?
Terpsmandan
Penn Yan
Yes.
Kleiss1
Gary
Arizona
Amazon has that same solenoid for under $30.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Keep in mind that the Warn disconnect is only rated for intermittent use. A continuous duty solenoid would be a better choice.
I used a 500a continuous duty mounted to the firewall with a piece of 2x2 aluminum angle that I notched to fit around the tab on the wire chase.
Jeep Wrangler JL Installed WARN Power Interrupt Kit - A few notes FCC985EA-A799-47D5-BCB7-D1A86AD3DFCA
Kleiss1
Gary
Arizona
So a 300 or 400amp at least?
jaymz
Jay
Inland Empire
Depends on the winch specs, but 400 amp continuous should be sufficient for pretty much anything that you'd put on a Jeep.
Don't get me wrong, an intermittent duty solenoid is probably fine and will likely never be an issue. But considering that a continuous duty solenoid can be had for the same money, it's one less thing to think about while you're doing a recovery.
Terpsmandan
Penn Yan
i don’t think so; check your Owners Manual, but in my ‘21, Aux #3 is one of the smaller-gauge (15A?) wires that J**p recommends for the small LED lights.
@Terpsmandan
Yup, my bad. The solenoid only pulls less than 5 so Aux 3 will be fine.
pmarold21
Paul
Memphis
2022 Jeep Wrangler 4xe Rubicon (Gobi)
Just finished with my install. Had to fabricate the bracket for the solenoid (decking brace cut to size and then plasticized). The 4xe battery and fuse box made me look for a different spot. Pretty pleased with how it turned out.
Jeep Wrangler JL Installed WARN Power Interrupt Kit - A few notes IMG_0599
Jeep Wrangler JL Installed WARN Power Interrupt Kit - A few notes IMG_0600
Jeep Wrangler JL Installed WARN Power Interrupt Kit - A few notes IMG_0601
doc_riverz
dave
Austin, Tejas
’24 JL 2-door
Porsche tech, paramedic, fire engineer, retired.
For peace of mind, I decided to install this. I read up on other installs, decided not to go direct to battery, and got some good ideas.
First what do you get for $80-$100 depending on where you purchase it – you get this:
I used my Aux Switch (simple hookup to Aux2) so didn’t use the switch and associated wire harnesses. I went with the Strong Tie 24Z Bracket, not the smaller 23 which had been recommended.
The 24Z is a perfect fit and the right strength to never have to worry about it. It slips between the Fender and Chassis and allows the Solenoid mounting a large enough surface. On the 23 Bracket, the ends of the Solenoid mounts were protruding past the ends of the Bracket. I then drilled the holes for the Solenoid and Bracket mounting and painted it with this product:
Great coverage after 4 coats and a little extra protection. After that made up my Ground Strap Harness
and connected it to a chassis ground stud available right at the Bracket location. Then added a wire loom to the provided positive harness.
After that I drilled 23/64” holes for M6 Inserts, painted the holes for protection, installed the Inserts
and then bolted everything up - used blue Loctite on fasteners-
(Do not forget to slip on the Terminal Boots) Installation came out good and is very sturdy.
Excellent install report! Appreciate you taking time to share this clean install with us.
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
I know this is old, but thanks for the info. I just added the Warn Interrupt switch to my set up. Works and looks great!
Looking good. Textbook.
Terpsmandan
Penn Yan
Exactly what mine looks like. Only issue that I can see is that it has to come out of you replace the battery.
