Inner fenders
GRXKen
Ken
Cedar Lake IN
2021 Rubicon, 2010 F150, 2016 Escape, 1970 GTX
Own and operate a remodeling company
Any suggestions on replacement inner fenders? Nothing flashy just functional.
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
The best flashy is no inner fenders. Easy maintenance and easy to clean . Plastic is a joke for protection. A blown tyre will take it out and what wires are nearby just as easy as with no fender what so ever.
TravelerTheJLU
Hunter
North Carolina
2023 Jeep Wrangler 4xe Rubicon 20th Annv
I went with amazon liners, the logos unscrew and you can paint them an accent color or black if you desire, they worked well and not terribly expensive. Prime day is also coming up I believe, and they went on sale last time.
Nilight fender liners
bllprk
Kalamazoo, MI
2008 WK CRD
OEM is king if you ask me. They just fit. Easy to remove and install. Never seen a non-trailer tire explode? Unless you need a replacement because you changed the flares, then I would keep it simple. No rattle, no rust.
Medsker
Jon
South Jordan, Utah
Retired Engineer
I'm getting American Adventure Labs. They make some with cutouts for Falcon 3.3 shocks which I'm also planning on getting. I agree stock work well but I'm doing a fender chop to help me fit 40's and need to replace the inner Fenders for that.
mgroeger
Southern UT
2021 JLUR 2.0T
Factory liners blow. They are not easy to just pop in and out, they do an amazing job at keeping dirt up behind them and they look ugly. I've run both Motobilt and Artec up front and liked them a lot. Once installed they are easy to take off should the need arise. I never put any liners in the rear, just simply painted the area black. That way it is easy to clean up any dirt and mud.
yokramer
Snark Incarnate
Im running the high clearance motobilts up front and standard in the back and they installed super easy and a breeze to remove if needed.
Terrymo
Terry
2023 JLURXR 3.6 ET
I have Motobilt and they‘re generally covered in dirt or mud…so not flashy. Painted rattle can low gloss Rustoleum bedliner.
flick2614
Randy
AZ
2021 Jeep JLU Rubicon Diesel
CavFab painted with Steel-It
GRXKen
GRXKen
Ken
Cedar Lake IN
GRXKen
GRXKen
Ken
Cedar Lake IN
I am running on stock size tires and suspension. With the sway bars disconnected and the wheels turned the inner fenders were damaged while off road.
I don't want to go without because I would like to keep sone dirt out of the engine bay.
To define flashy I don't need bright colors, the "best", strobe lights and blue tooth. I would be satisfied with OEM but I feel like the result would be the same
mgroeger
Southern UT
2021 JLUR 2.0T
If you want cheap and others to look down on you then go RC. If you want cool and others will pay to wheel with you then go Motobilt, Artec, American Adventure lab or the like :)
GRXKen
GRXKen
Ken
Cedar Lake IN
I like the American adventure, aluminum and quick release
