Thanks... yeah they fit real good, they’re light weight but yet sturdy when all bolted up. There’s a couple small things on the passenger side that I did to make installation easier.They look good! Thinking about these as well. How’s the fitment and mounting? Does everything line up, no gaps, sturdy?
Thanks for the tips and pointers!Thanks... yeah they fit real good, they’re light weight but yet sturdy when all bolted up. There’s a couple small things on the passenger side that I did to make installation easier.
There’s a plastic box/cover that’s held with a push pin, they give you a flag nut for there, just make sure it goes over the cover and that makes it hard to hold in place. I used needle nose pliers to hold it.
On that same panel the bolt in the middle is almost impossible to reach the nut on the back, so I did a clip nut there otherwise the instructions are pretty good. Here’s pics of trouble spots.....
In the rear, did the fenders come with rivnuts? I just picked up a set but there is no way to bolt it to bodyI’m running same lift and tires , I can relate.....
On the rears if I had to do it again, I would have taken the tires off, it’s a lot easier. The fronts are only 2 pc, but backs are 3 pc.
Ok dude..... you got me wondering, so I went out and took my fender apart ....lol. Mine came with those spots threaded,five locations all threaded. The nuts were attached from the factory. Not sure why yours isn’t. But hope this helps, like I said a clip nut on those flanges should work if you don’t resolve it any other way.......In the rear, did the fenders come with rivnuts? I just picked up a set but there is no way to bolt it to body
I worked with northridge4x4 since i bought it from them. They worked with Artec and shipped me a whole new set of rears to fix the issue.How’d you make out, is artec stepping up ?
That’s awesome..... I only use northridge 4x4, unless they don’t carry something. They’ve always done right by me. Glad it worked out for you.I worked with northridge4x4 since i bought it from them. They worked with Artec and shipped me a whole new set of rears to fix the issue.
