HOW TO SET CASTER
Big Juan
Juan
Santa Rosa ca
2018 Rubicon
Hello out there,
I am installing a MC 2.5” game changer lift on my 2018 JL Rubicon.
I am nearly ready to start setting caster and pinion angles. I am doing the work out on my carport which is very out of level an uneven. I also just bought the Klein digital angle finder.
My question is, does the jeep need to be perfectly level to find the proper angles?
Any help and tips will be greatly appreciated.
Thanks.
jadmt
jeff
montana
Yes you want to be on a level surface
Nokones
Kenny
Sun City West, AZ
23 Rubi, 21 Silverado, 13 Grand Sport, Cayman GTS,
Unemployed For The Rest Of My Life from a career of spreading love, cheer, and joy to lots of special individuals that were asking for attention..
And on a bubble/laser level alignment rack with turn plates.
As for the pinion angles, you do not want more than two degrees difference between the pinion angle and the drive shaft.
Deleted member 107602
Guest
You want a relatively even surface. It can be at an angle, you just need to sit the Klein on the ground, zero it, then take your measurements at the appropriate locations to get the relative angle to the ground plane for the caster. The pinion angle is relative to itself so zero it to the yoke and then measure the shaft.
D00KEY
Andy
Thornton, CO
2021 392. 2019 3.6
Take it to a shop. Once on the rack set your angle finder on the knuckle or ball joints. Take a picture of your measurement. Then you know where you start and can adjust from there.
jadmt
jeff
montana
ditto
JP52
Walnut Creek, CA
2022 JLU Rubicon XR
I put pieces of wood under my wheels to level out my jeep when I did this. I just jacked up each wheel at the axle and slid plywood or 2x lumber as needed. I used a level on my sliders and bumpers. It worked well.
