Thanks, good info.Voltage, not current ?
The power supply posted above would work as long as the full load amps of the compressor doesn't exceed 10 amps.
Otherwise find out what the FLA is of the compressor and Google search 12vdc power supply "x" amps
Thanks, good info.Technically speaking No, you can not transform A/C to D/C. But you can rectify it. You can build one yourself if you can’t find anyone offering the capacity you need. I’d recommend buying a small 5hp 230v single phase 120v A/C compressor for you house though. That D/C compressor pulls more than you’d think, and most likely the published amp draw isn’t considering the service factor amps that a compressor will pull near then end of its load. So I’d recommend checking your amp draw at whatever your final psi is before continuing the project.
