How to open this connector??
yokramer
Snark Incarnate
Thats just a standard connector, push down on the bit that bends down and pull them apart. If it isnt going push the 2 halves together and try again.
Terrymo
Terry
2023 JLURXR 3.6 ET
Are you talking about the brown connector? if so yes as @yokramer already said push the two connectors toward each other, push the lever down outlined in black, then pull the connectors apart making sure not to pull on the wires themselves. Today I’m just repeating everything yokramer says so I seem smart
Jeep Wrangler JL How to open this connector?? IMG_1030
yokramer
Snark Incarnate
If only more people realized they would be better off for it.
ppjcs
Paul
Victoria, BC, Canada
2020 Wrangler Rubicon
The other responders are correct. I have a tool that is meant to help push the tab down which makes it easier. I have seen a mechanic use a flat head screwdriver to push the tab down but you have to be careful with that method.
gek
Code Monkey
Jeep Wrangler JL How to open this connector?? {filename}
