How did you wire your winch?
  • Total voters
    182
GtX
Illinois
2020 JLUR 3.0D
Working for the man.
That is well done but it is also A Lot. It looks like you have the V6. The 2.0 as shown @PocketsEmptied pic is what I have. One of my goals is to insure that I don't hinder access to anything I might need in the future. For example, I don't want to have to remove my relay to get to he battery mounting bolt. Further up the thread there is someone that used the bolts on the firewall/cowl. That's not bad either but I also wanted to keep this all as far away from engine heat as possible.
That's a 3.0L diesel . I also have a fuse panel in the middle along the firewall for my rock lights. It's really just a few bolts then the whole assembly rotates out of the way.
Catiajockey
Jon
Melbourne FL
2018 JL Rubicon unlimited
Not 100% on the routing for the cable to the battery but it functions as it should. I'll clean it up tomorrow. Signal is from aux 3. The bracket I found at Lowes in the lumber section. I just drilled it and painted it with some engine enamel.
Jeep Wrangler JL How did you wire your winch? IMG_7024
Jeep Wrangler JL How did you wire your winch? IMG_7025
iddpaul
Paul
Central Florida
2025 JLUR, 2023 JTRD
So I bought a VR 12 and wanted to say thanks for everyone's post...helped me greatly clean up the connection and relocate the control box to provide better air flow to the radiator. (thx @Roky for your pics as well). Added a relay and moved the control box under the hood. I no longer have my workshop so instead of fabricating everything as I once would have done, I just looked for other brackets and cables that would work. I bought the 7' relocation kit from Vice Designs (excellent product and service), pulled the air box and inner fender and ran the cables from the winch up to a new bracket mounted on the firewall. Connected the cables, added a relay, connected to the Aux 3 switch and then bought a cover for the winch (Amazon $12) to finish everything off. Thx again and hope this gives some ideas..!
Jeep Wrangler JL How did you wire your winch? winch relay
Jeep Wrangler JL How did you wire your winch? winch control  relocation
Jeep Wrangler JL How did you wire your winch? winch relocation bracket
Jeep Wrangler JL How did you wire your winch? winch Vic
Jeep Wrangler JL How did you wire your winch? Winch Final
Jeep Wrangler JL How did you wire your winch? winch no control
Jeep Wrangler JL How did you wire your winch? winch 9
Roky
Roky
Looks good brother , nice work !
iddpaul
Paul
Central Florida
Thanks Roky...greatly appreciated everyone's posts and pics...the biggest tip is to remove the airbox and inner fender to run the cables...very easy to do and then allows unlimited access and a way to wire-tie everything in place.
