How Can We Help?
2nd 392
Ca
I have no idea on why they are mentioning cruise control, I just did a quick search on disabling MDS and didn't know that you could do it by going with the shifter and also by going with a tune
They did have a link to toms4x4superstore in TN and they had a 21 392 that they did a cam/lifter change in order to get rid of the MDS. There is a short video of it I believe on FB but for some reason I can not get on their site..
Cam lifter change only as a last resort due to CARB and no at least stage 2 cam upgrade for the cost without flunking the F’ing Smog Check ? Hell- a stage 1 might flunk, too big a gamble unless there is an approved one I don’t know about. I have researched, but not extensively. I have watched some worthless videos. Tunes as expected, one idjit made a big deal of Manual Shift disabling for Free, no tune needed :facepalm: .. ….. I immediately subscribed noting his knowledge and brilliance.
dstevens
CA
2024 JLURX
I'm looking for the plastic bracket on the right rear interior next to the rear seat belt spool. It supports an electronics module and also the trim 6BM34TX7AB clips into it. The module might be TMPS or a seat belt tensioner or for the rear air bags. It's hard to know what category to find the bracket - 99% of the search is finding out what it is called.
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
The receiver hub is located in that area but the bracket looks to be metal, Let me know if this looks like it?
Jeep Wrangler JL How Can We Help? 1703635041173
-Benny
TerraJL
TN
2023 Jeep Wrangler Unlimited Rubicon 6MT
Looking for the transmission drain and fill plugs for my 2023 Rubicon 6 speed manual. Every dealership I call has said they cant get them. Plus, I need the gaskets to go along with both plugs. Any help, AllMoparParts?
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Hi,
There seems to be an issue with obtaining the fill plug. I will need to forward this to our parts rep, In the meantime all links are below.
Fill Plug
https://parts.allmoparparts.com/oem-parts/mopar-plug-5191362aa
Drain Plug
https://parts.allmoparparts.com/oem-parts/mopar-plug-68019658aa
Drain & Fill Gaskets
https://parts.allmoparparts.com/oem-parts/mopar-transmission-case-gasket-5191062aa
Once I hear back I will reply here.
Thanks,
- Benny
DaMaDo
Huntsville, AL
24 Rubicon X 4xe
Thanks Benny - one more thing - what else do I need to make swapping grills with a camera easier back and forth? I think there's the washer fluid nozzle and quick disconnect. Do you have links to those also? Is there anything else related to the camera (besides the actual camera)?
Note, I'm swapping between my 2024 grille (new connectors?) that came with a camera and the older model grille that I will paint black.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
There is a camera bracket specific to the 24's PN 68566612AA. Youll have to re-route the wiring and use a few zip ties as the 24 harness is routed differently. Other than that we have not heard of any issues.
- Benny
ganshert
1990 XJ, 2024 JL
fczabala
FL
JLUR; X5
Hey Benny,
Looking for spring isolators, front upper, left and right
Thank you
danba
Johnny
Southwest
Looking for the front cage mounted handles for a MY2024 392 with SOT.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
