How Can We Help?
fczabala
FL
JLUR; X5
AllMoparParts.com
AllMoparParts.com
Peak Sponsor (Level 2)
Benny
NY
2018 JL
Thank you! Any particular reason why the system is charging $20 for local pickup?
The dealership prefers to deter local pickups, For forum customers we can waive this. If your interested please PM me your email address and I will send a custom quote.
Thanks,
- Benny
DaMaDo
Huntsville, AL
24 Rubicon X 4xe
There is a camera bracket specific to the 24's PN 68566612AA. Youll have to re-route the wiring and use a few zip ties as the 24 harness is routed differently. Other than that we have not heard of any issues.
- Benny
Thanks Benny
Trying to compile all the parts I want so I can order them all at the same time.
1. I need the camera wash nozzle, pipe, and quick connect nipple shown below (sold as an assembly?) so I can just connect it with the factory quick release connector.
Jeep Wrangler JL How Can We Help? Front camera washing system
2. I need whatever parts are used to hold the front camera on the 2018-2023 JT grill insert trim part (larger hole version).
Jeep Wrangler JL How Can We Help? camera bracket
3. I need the 2024 grill vertical trim slot covers (the 5 in the middle, not the two ends).
Jeep Wrangler JL How Can We Help? 2024 grill trim piec
TerraJL
TN
2023 Jeep Wrangler Unlimited Rubicon 6MT
Hi,
There seems to be an issue with obtaining the fill plug. I will need to forward this to our parts rep, In the meantime all links are below.
Fill Plug
https://parts.allmoparparts.com/oem-parts/mopar-plug-5191362aa
Drain Plug
https://parts.allmoparparts.com/oem-parts/mopar-plug-68019658aa
Drain & Fill Gaskets
https://parts.allmoparparts.com/oem-parts/mopar-transmission-case-gasket-5191062aa
Once I hear back I will reply here.
Thanks,
- Benny
Benny,
Any update from your rep on this?
Good jeep
Las Vegas, NV
Wrangler Rubicon 392
Benny is there a kit available for installing shift paddles on the JL. Why shift paddles on the 392 not other Rubicon.
I have a 2022 Wrangler Rubicon diesel.
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks Benny
Hi,
Here are the part numbers and years I looked them up for
2024 washer nozzle 68370210AA
2024 jumper hose 68370828AB
2022 camera bracket 68396526AB
2024 trim ring panel 7HQ96TZZAA
Please let me know if there is anything else
- Benny
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
DaMaDo
Huntsville, AL
24 Rubicon X 4xe
Hi,
- Benny
Thanks
For the trim ring, do they only sell it as a set of all 7? It's $195, was expecting $10-$20.
For the hose, I need the little one that goes on the nozzle. I think the part you linked is the longer one that goes from the Jeep to the small one on the nozzle - see #6 below
EDIT: I think it's maybe 68370825AA
Jeep Wrangler JL How Can We Help? 1704235281208
AllMoparParts.com
AllMoparParts.com
Benny
NY
2018 JL
Thanks
The grille rings are one complete panel that includes the headlamp bezels as well. Good call on the washer elbow, I agree that is the correct #.
- Benny
GrayHawk20
Cory
*See Signature for Info*
(Architectural) Jr. Project Coordinator
Looking for the front cage mounted handles for a MY2024 392 with SOT.
Just a heads up, even though there is no disclaimer I dont think they will work because the rail is in the way. My 2021 has the SOT and I was looking at installing them but when I look at closer I realized I wasnt going to be able to order them, if you do get them to fit with a SOT that'll be awesome.
danba
Johnny
Southwest
There is a specific part number that @AllMoparParts.com states it works with the MY24 SOT: SKU# 82219166AA
However this part is not available just yet, so I suspect you installed a different one. Also the MY24 are different than the MY23.
