How boned am I?
OBD
Thomas
Arkansas
2021 Jl Wrangler ,2016Soul,Dyna,Sportster,HD
I would use a high-tech plug and use it for a spare.
TwelveGaugeSage
Massuhtwoshits
2022 JTR
Defininitely spare material. I drove around with a spare for a long time that had a gash in the same area. Stuck about 5 plugs in it and mounted it to the back of my TJ. Just spray it with some soapy water after plugging to make sure it's plugged up well. Check it again in a few weeks.
Old Jeeper
Don
US Army Infantry, IT Engineer
Might have to do that one yourself. Depends on who you know at shop!
X2 and if you can make it your spare.
IF you pull the nail out does it lose air immediately?
Spartan99
US
2008 JKUX
Maybe use as a spare and drive carefully if ever used.
Rick4570
Virginia
2022 Jeep Wrangler
Sucks when this happens! And it usually happens to me on new or low mile tires!
NAZJeeper
Woody
Northern Arizona
2015 JK
I do agree that the hype about sidewalls is overplayed by the tire companies....but....on the other hand........ we're not talking $3k here, just $300. I'd patch it and throw it on the back for now, but get you a new one as soon as you can (afford to......?)
Koolkarguy
Shane
Wyoming
2021 Hydro blue Jt 2012 Gecko green Jk 2021 Gecko
35" KO2 7K miles. Immediately started spewing air when I pulled it out. Tapped it back in until I can bring it in to tire shop.
Any chance I can find a shop to patch or too far into sidewall? Or would this be something I am likely going to have to take on myself?
Was able to finally get that fifth tire rotated in though :CWL:
Plug it and put it on it'll be finevworse case is bad plug might leak probaly last as long as the others can't imagine it harmed the integrity of the tire
KCSgtMaj
Andy
KC
MY24 Rubicon Unlimited, 3.6L
Retired Marine, Master Plumber
Any sidewall tire puncture is a replacement.
bradcrc
Minnesota
JL
Every time you hit a bump or dip, you have the potential of some big flexes in the sidewall, bad conditions for a patch to hold well.
if you're really lucky, it could hold.
if you're lucky, it could eventually just start to leak again.
if you're unlucky, it could blow or go flat at a bad time.
if you're REALLY unlucky, it could blow at a really bad time and some bad schist could happen.
IMO, not worth risking it for a few bucks, and I'm a cheap bastage. Few bucks now may save a crudload of headache later.
Kind of like eating expired mayonnaise, you'll most likely be fine, but if you get unlucky you could get really unlucky.
Old Jeeper
Don
That is NOTHING LOL
Check this out:
Somewhere, somehow in my wheeling I got a Round quarter sized piece of rubber ripped out ??? Next to was a vertical slice to the right of it, It could have been vandalism???
But my GY 37 MTRs held up and I wheeled for another year and it finally gave up the ghost down in Mexico wheeling along the Sea of Cortez.
I bought a tube of Shoe GLue and forced it into the openings, worked. I finally switched over to BFG KM2s and sold my MTRs.
Jeep Wrangler JL How boned am I? 31052007306
Jeep Wrangler JL How boned am I? 31052007307
Wulfgang
Richmond In
2020 Jeep Wrangler Sahara
Have the tire removed and patch it from the inside.
I wouldn't try a "tire patch kit" from the outside.
Use it as a spare.
If done right you should be good to go.
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I'm not saying that you should do this, but do this.
Jeep Wrangler JL How boned am I? 1879-plugpatches
NBB
Boulder
21 JLUR
Plug it and done - that tire isn’t going to fail catastrophically - just not seeing it - giant tire, tiny damage. Such a waste to not wear that thing out - lighting money on fire for nothing.
