Hotheads For Sky One Touch
JeepJP
Jason
Pennsylvania
4Xe
Finished installing my Hotheads sky one touch liner and sun shade. Graphite for the liner and black for the sunshade. They both fit really well with the one touch top. I will get some pics up.
How do you like the black/gray hotheads sunshade? Not sure which color you have. Looking to purchase but also want to be able to look up and see the trees, moon at night, etc. Is this possible? Not sure if white is more transparent.
Covet
Los Alamos, NM
18 JLUR, 22 392, 22 4xe JLUR sold x3, 24 392
I have the black sun shade (and the grey liner). I don't know if the white would be more transparent, I have never been in a Jeep with a white one. Had a olive green sunshade on my previous JL, the visiability with that one is relative to the black one I have now - my opinion.
I got the black thinking it would match well with the black SOT top - and it did, threw on the grey headliner to try to get some color variation, I like the combo.
Apexcars
North Texas
2020 RAM 1500
I cannot understand the picture. Is this a sky touch roof? It looks damn good. Does it roll back with the roof? WTH - I have not seen this before… going to their website!!
Yes, and install is very easy. I was very concerned with getting the Velcro strips just right on each crossmember and making everything very even. Then once I started putting in the actual fabric I realized that it really doesn't make any difference. You are just sticking a big blanket to the roof with Velcro. Helps some with noise and it has helped a lot with the cabin temps.
df007
2019 JLU Sahara 2.0
I've had one of these for about 4 years and love it. BUT......slowly all the adhesive on the velcro is starting to fail.
It started with the rear header piece and the dual-lock velcro seperated from the VHB (the part that i cleaned and stuck to the rear header stayed stuck). I was able to heat that up a bit and get most of it to stick back together, but not at some of the edges.
Now slowly all the normal velcro on the rails is starting to fail on the outter edges and started to sag down. I haven't been able to get these to re-stick.
I imagine it would be a PITA to replace all this and try and get the glue off the rails.
Has anyone here done this and have any tips?
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
@Hothead Headliners, any suggestions on how to mitigate this issue? I'm pretty sure Santa will be bringing me one in a few days.
Hothead Headliners
Summit Sponsor (Level 3)
Mark Ambrose
Bosie, Idaho
hotheadheadliners.com
2018 JLU, 1989 YJ
Hi, im glad you love the headliner. If you are having issues with any of the Velcro or 3M just reach out to us and we will take care of any issue. My phone number and email are on our website. We will always take care of any issues anyone is having and let them know them know the best & easiest way to do it.
Hothead Headliners
714-872-2071
Ratbert
PNW
Software Engineer
Hothead Headliners
714-872-2071
You messed up the formatting a bit (scroll up to see), but thanks for the reply. It makes me a bit less nervous about that.
JeepinPete
Pete
PA
'19 Mojito JLUR
Mechanical Engineer
I went through this. Hotheads was stand up, sent out a new set of velcro. I asked their advise for removing the residue, the reply was to reapply it over the residue which I did. Don't do that, the velco fell off pretty quick.
Getting the adhesive residue off is going to test your patience. Nothing I tried really cut it. Both forms of Goof-off, Liquid Wrench penetrating oil, WD-40, brake clean, carb cleaner were all tried. The best were the citrus Goof-off gel and penetrating oil. I would saturate a microfiber cloth with Goof-off and saturate the rib then let it sit for 10 minutes or so. Then I used a poorly molded plastic tool with heavy flash on the mold parting line as a scraper to scrape off as much residue as possible. Rinse and repeat several times until you are down to a film. Then use penetrating oil with a microfiber rag and rub off the last of it. Clean with isopropyl when you are done. I did manage to clean all of the ribs without getting any on the top over the course of several days.
Since you have had it so long, you probably have the same setup I did with velcro strips that attach to the face of the ribs. The new velcro is twice as wide and wraps around the ribs. It seems to hold much better.
Pete
MarkyMark
San Francisco, CA
19 Rubicon JLU 2.0t w/ eTorque & Moto Guzzi Griso
Just providing a quick update. I've had mine on since the very earliest days. (One of Hot Heads first customers on this). I absolutely LOVE it! No issues with it coming off / down. Velcro has held fine. It was an easy install. Made a huge difference for me on cabin temperature and especially noise. It also cleaned up the look of the cabin. It basically make the Jeep look the way it should have come from the factory. . . . I've done a lot of mods to my rig, but this is probably the best.
df007
2019 JLU Sahara 2.0
Thanks for getting me squared away!
Turns out I had a VERY early version with thinner velro strips on the cross bars that gave up a bit.
They sent me an updated set and it looks like it will hold up very well.
Thanks!
houstonstroker
2021 Wrangler JLU
I recommend cleaning the rail surface with alcohol and then applying adhesion promoter. You can buy small wipes or buy a bottle from Amazon.
Ratbert
PNW
Software Engineer
According to this SOT-based installation video they include adhesion promoter for where it's needed (when attaching to plastic).
