Hood Solar Panel Installed
2019JLUS
19' Sport S
  • Thread starter
  • Banned
  • #1
2 hours later, solar hood panel installed. Why? Because I don’t drive my jeep enough to keep the battery charged. Been having to jump start more and more every month. It’ll also keep my dash cams on longer during parking mode. My electronics use around 100 amp hours during the week while parked and the solar panel with a conservative 5 hours of sun per day should generate a little over 200 amp hours leaving me with 100Ah to spare
The brand I used is Lensun's 90w kit: https://amzn.to/43x6UTl
Jeep Wrangler JL Hood Solar Panel Installed IMG_0461 Jeep Wrangler JL Hood Solar Panel Installed IMG_0460 Jeep Wrangler JL Hood Solar Panel Installed IMG_0397
My only tip for those who don't have a heat gun is to leave the engine running when installing the vinyl layer. The heat will help get the hard to adhere spots.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Isn't it generating about 7.5 amps per hour, so about 37.5 amp hours when at 100% for five hours, right? Assuming it's all 12v.
Maybe you meant per week?
2019JLUS
2019JLUS
19' Sport S
  • Thread starter
  • Banned
  • #3
More like 6Ah/hr around 30Ah/day (conservatively) 7.5Ah would be tough to achieve, would need perfect angle and conditions.
Yes, the numbers are weekly estimates.
Ratbert
PNW
Software Engineer
There are some times when not having a Rubicon (and its hood) is advantageous.
2019JLUS
2019JLUS
19' Sport S
  • Thread starter
  • Banned
  • #5
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Or you can do what I did… not flush but 175W panel on a Rubicon. More details in my build thread. This powers my onboard power station and fridge/freezer. The power station can back-feed my battery if charge needed.
Jeep Wrangler JL Hood Solar Panel Installed IMG_2551
2019JLUS
2019JLUS
19' Sport S
  • Thread starter
  • Banned
  • #7
Cant, enjoy my open air freedom too much
Jeep Wrangler JL Hood Solar Panel Installed IMG_0421
dragoneggs
Seabeck, WA
Me too… I get it. I love the concept… should be an OEM option.
Obviously not an option for a soft top and not trying to highjack.… just throwing out other alternatives for folks to consider depending on their needs.
I can quickly disconnect the solar when I take my hardtop off in the summer for a few weeks at a time.
linux_guy
Alabama
2020 JL 6-speed manual, 2011 Compass 5-speed manual
I'd love to see what folks have done with Renogy panels. Owning Ego batteries and inverters (because mower and yard tools), it's the ecosystem to which I'm married.
Stagewex
Westchester County, New York
2025 Wrangler JLU Sport S, 2002 Porsche Boxster, 1974 VW Super Beetle
Hail for about 30 minutes yesterday in Florida. Pix from my brother who lives close to Vero Beach. I don't have to tell you what happened to all the Solor Panels on everyone's roofs. Many will find their homeowners insurance will not cover. Auto... who knows?
Jeep Wrangler JL Hood Solar Panel Installed IMG_0864
I would not install permanently on a Jeep (or anything else). Especially if going off-road. But that's just me. It is a cool option/concept.
dstevens
CA
2024 JLURX
He's what I did a year ago for the same reason; don't drive the Jeep very often.
https://lensunsolar.com/collections...angler-jl-rubicon-lensun-50w-hood-solar-panel
Jeep Wrangler JL Hood Solar Panel Installed 033-
https://www.jlwranglerforums.com/forum/attachments/033-jpg.896612/
I'm not sure I would do the same thing again. The 50W panels put out only 18W under optimum conditions, but the main issue is that their voltage (17.5V maximum) is not that much over 12V charging voltage of 14.5. The controller is PWM, so you need the panels in the sun before the battery will charge. A MPPT controller would help a little but the real problem is the type of solar cell used. The 55W panel from the same company has a higher voltage (19V) so would work better.
CIGS panels are better but they only seem to come in oddball sizes and they are low efficiency so need to be large.
Probably I just need to swap out the PWM controller for a MPPT but they don't usually start until the PV voltage is 5V over the battery voltage, so again the low PV voltage is a problem.
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
First off OP, that looks nice.
Using an MPPT controller versus a PWM gives you a little more efficiency as well. Whilst solar panels love the light, they hate heat and lose efficiency as they get hotter. Not a big concern while driving but the heat off the hood will shorten their life versus elevated roof mounted panels.
What’s sad is you had to come up with a countermeasure to address the parasitic draw from Jeep’s inept design. Keep in touch with this, I’m curious as to how long it’ll last.
PhrogUSMC
Edwin
Virginia
'21 JLUR
We bought a used Gladiator Overland last Oct that has what appears to be the same, or similar, solar panel on the hood. I like the idea of it, but my gf (who owns the Jeep) wants it removed. The previous owner built the Jeep for Overlanding, with rack, RTT, awning, solar, snorkel, onboard air, etc. She's already sold the rack, awning, and RTT and replaced with a chase rack. She wants to replace the snorkel and reinstall the factory painted cowl cover (which I have to buy on ebay). She also is going to wrap the Jeep which will require removal of the solar panel. I'm not sure how to remove it. It's on there good. Heat gun, maybe. Can't reinstall over the wrap, and I have a Rubicon. We have a lot of Jeep friends. Can probably find someone who will buy it. Gonna keep the charge controller though, for either our camper or cargo trailer.
2019JLUS
2019JLUS
19' Sport S
After a long drive, leave your engine on to keep the hood warm and use strong floss or fishing line and floss the panels off the hood. Then you’ll only have vinyl wrap to deal with and that can be peeled off by hand. If it doesn’t have a vinyl layer then you’d have to either use a tar remover or an eraser bit
example:
