Joe Paul
I agree. For the amount of money they charge for the wire harness, they should supply the plug to wire in for the controller; GM does. The blue wire is long enough to go to the glove compartment, but that's it. I'm sure someone with have a plug to wire into the JL, if not already.Did some research. Yes, the blue wire is for the brake controller (purchased separately, of course). The brake controller will also have (and need connected) a positive and negative hooked to the battery and a red one that runs to the brake switch on the back of the brake pedal.
I've said this before on one of these hitch threads that I'm disappointed that there is no brake controller socket preinstalled for connecting it easy. However, if you have the hitch factory installed, you DO have one. We get penalized for not getting it on the front end, it seems.
