Hitch lock seized up!! Any ideas?!
KnG818
Ma
18 Rubicon
So, I'm trying to remove my Factor 55 which I had secured in with a lock pin(masterlock pin). Trying to put in hitch with ball to tow something.
Totally seized up.
I've tried heat gun, wd40 - NOTHING, key wont even slide in, the tumblers are totally seized.(yes it's the right key).
Any ideas or easy way of cutting it off with ruining anything?
OldGuyNewJeep
Don
CT
Totally seized up.
Happened to me years ago. I used a Dremel. It took several cutting discs and a steady hand to keep from scratching up the hitch. I’ll never again use a hitch lock. They’re crap.
KnG818
KnG818
Ma
18 Rubicon
That's my next move. Was think of drilling out the lock, not sure how that will turn out though.
Am so bullsh*t right now.
JeepAddict
Rochester, NY
'20 Rubicon Recon
Definitely try something strong than wd40:
Look for CRC Knock’er Loose at any automotive store. Get the aerosol with straw to spray into the mechanism and let it sit a few hours or over night. Helped me with a hitch lock in the past.
KnG818
KnG818
Ma
18 Rubicon
Thanks bud will try
Hootbro
Don
Delaware
2018 JLU Sport, 2025 JT Sport
I have been through this myself and have cut off more than one hitch lock setup due to seizure of the lock assembly. I just now make a point of at least once a month during the winter months to clean, lubricate and exercise the lock mechanism.
viper88
Nick
IL
Maybe try applying a little heat with a propane torch before trying the key again? You can always cut it off if that does not work.
KnG818
KnG818
Ma
18 Rubicon
Yes, the tumblers were totally seized up.
Actually just got it off few minutes ago...heat gun and hammered the key(with caution) into the key hole all the way down. Then turned the key and it came off.
....phew, think I'm just going to keep my hitch empty until I need to use it. That really sucked think I may have to cut it off and scratch the shit out of the hitch.(maybe even just a cutter pin setup).
All good now though. Huge relief.
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
One should take care what lube they use, dust and dirt can stick to oil based lube. I've had trouble with locks in the past with this. As
@Ma$$iveDebtAche posted above the dry graphite lube is what I've learned works best though I doubt it will help with a seized lock. YMMV
