High Pressure oil pump hack...?
NPC 20883467
Over the Divide
'20 JL Sport S, '97 TJ Sport
As I understand it, the solenoid failure mode on our 2-stage oil pumps is to the high pressure mode. So let's say a person wanted to boost low engine speed oil pressures, you know, to help prevent oil-related cam & rocker failures. Would cutting the power to the oil pump solenoid be effective in doing that?
58Willys
Geoff
Western Washington
2018 JL Sport
If you run high oil pressure at low RPM’s, you activate high lift mode on the intake valves; doubt that would work well.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
That is controlled by a completely different set of solenoid valves.
NPC 20883467
NPC 20883467
Over the Divide
youll get a cel but not an oil pressure light....
So... If one were to route that solenoid wire through an auxiliary switch, one would have instant-on high oil pressure, replete with an indicator light...?
...i think the vvl defaults to high lift mode as well
That would be fun as well, but of limited utility.
Old Dogger
Bill
Cave Creek Arizona
When ones oil pressure sensor behind the oil cooler fails, the pump remains in high pressure mode. How do I know that, is because it happened to mine.
