Oil Pressure After Oil Change
SRQgunner
Russ
Sarasota FL
2018 Jeep Wrangler JL Unlimted Sport S
I just finished changing my oil with the proper oil filter and using 5qts of 0W-20 Pennzoil Ultra.
When I start the Jeep the oil pressure registers at 30psi. The pressure stays at 30 even as I begin to accelerate. If I stomp on it the oil pressure will go up but then go then return to 30psi.
The oil pressure functioned normal prior to my changing the oil.
Any thoughts?
SRQgunner
SRQgunner
Russ
Sarasota FL
What pressure were you running before?
What weight oil?
0W-20 . Pressure before at idle was like 30-32psi.
Maybe this is normal. I read another post where they were saying it stays around 30 until you get to 3000rom. I'll have to check that
jakebrake
philly burbs
2020 wrangler rubicon recon
It could always be a gauge reading wrong.
Stranger things have happened.
Bearded_Dragon
FL
2018 Mojito! Rubicon
This is correct.
cb4017
Cliff
Northern Nevada
2021 Gladiator Sport
Any thoughts?
Sounds normal.
Mine does the same thing. The oil pressure will suddenly climb at around 3,000 rpm but return to 30 psi below that.
Icon Vehicle Dynamics
