Help with offset choice
3pedals2doors
Missouri
2023 Rubicon
Looking at the Method 701 wheels. Should I go 0/4.75" or -12/4.60" offset?
2 Door rubi with 3.5" gamechanger/6 pack shocks. Mickey Thompson Baja boss 37s
Smoke Showing
South Jersey
2018 JLU
I went -18/4.79 on different wheels. Lots of poke but no rub whatsoever with a 3&1/2”lift. Only issue is rear camera makes me think I’m looking through the gates of hell.
Jeep Wrangler JL Help with offset choice 78461DB3-B527-49C1-95E3-693A5D70B284
Jeep Wrangler JL Help with offset choice 825D5002-05C7-43D9-AF06-CCF2AC4569CD
Kahunadave
Orlando, FL
2020 JLUS 2.0 Etorque; 2015 GrCherokee ltd 2wd
Auto Lending
Dont forget.. the negative - offset will add to the width of your Tires and how much your Tires stick out.
blnewt
New Mexico
Just ask @cosine he knows!
Gamechanger should have recommended offset/backspacing range for their lift, I'd contact them first, I'd lean toward that zero offset, but Gamechanger might need a bit more poke.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Out of those two specific offsets, definitely the -12mm. The Metalcloak Gamechanger is one of the most flexible lifts shy of long arm and coilover conversions. Especially with the optional 6-packs.
Discount Tire
Arizona, USA
discountti.re
All Things JEEP
Tire & Wheel Specialists
As mentioned, 4.5-inch backspace or less is recommended for this lift kit with those shocks.
