Help with Gaia
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
So I have created routes and dropped some pins for my trip. I can see my online work on my Gaia App...do I need to do anything else to be able to see my routes as I am navigating trails? Do I need to download maps?
Thanks.
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
Thanks.
You need to download the area you will be in in case you don't have cell service.
I really struggled with Gaia a couple of weeks ago. I wish there was a "Gaia for dummies" or somesuch...
dchemphill1
dchemphill1
Nebraska
So is download the same as syncing? I do see a spot that has download as GPX, KML or GeoJSON...if that is it which should I use?
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
In the app, up top, hit the plus sign and “create area” will be an option. That’s what you want.
Mojave Dust
Glenn
Mesquite, NV
www.vv4x4.com
2021 JLURD, "Daredago"
retired CIO; professional dilettante
The GaiaGPS app works a little differently depending on whether you have the Apple or Android version. I use the Android version, so that's what I'm familiar with. "Syncing" will just sync your downloaded maps, waypoints, routes, and tracks between devices so you can see them on the web version and other devices. Your tracks will show up, but if you are in an area without cell coverage you may not be able to see the map you want.
An easy way to make sure you have an appropriate map downloaded is to go to the track "details" page, and click on "download map along route". That will download tiles for whatever map you currently have selected along the entire track, and will be viewable even if you don't have cell service. As far as a map choice, "Gaia Topo (feet)" is usually pretty good.
You do have to have a paid Gaia subscription, not the free version, for this to work.
Odyssey USA
Daniel
Indiana
www.youtube.com
2021 JLU Rubicon
That’s a good one I forgot about. Probably a lot of space saved. If you do go exploring, I’d save the whole area…just in case. One might have to detour.
dchemphill1
dchemphill1
Nebraska
Thanks all for your assistance...I think I got maps downloaded on my android phone using the app. I should be good to go if I don't have cell service.
txj2go
DFW
Did you pay for a membership? That's the other thing- you have to pay for a membership in order to download maps that can be used even if you don't have cell service.
jdhunt0
Kentucky
2019 Wrangler Unlimited
Which map do you recommend downloading for trails around Moab?
dchemphill1
dchemphill1
Nebraska
Yes. I did during the winter and started building my trail routes. But was struggling with the download. I have now downloaded some areas and tried downloading the area when I pull up a Route. See which works better.
Thanks
Mojave Dust
Glenn
Mesquite, NV
www.vv4x4.com
If you are asking about which map layers, the Gaia Topo (feet) will show just about all the trails around Moab. Just be sure to set the zoom level as high as possible if you have enough memory. For some of the more desolate areas here in southern NV, I also load the US Topo layer which has a lot of the old mine and ranch roads. The Mines and Minerals layer is also great for exploring if you're into that.
txj2go
DFW
I got the cheapest membership which only allows download of the basic GAIA topo map. It worked fine for my trips around Moab and Capitol Reef. I could download a very big area into my old iphone6 that probably has the minimum memory capacity. The mines and minerals layer does sound interesting though.
