Help with error codes
MattyAces
Matty
New Jersey
2021 JLU Willys
Hey guys got a 21 Willy's unlimited and the bitch won't start. Hooked up a scanner and it gives me these codes but doesn't have any info stored on em...can anyone let me know what could be the problem?
Jeep Wrangler JL Help with error codes Screenshot_20260506-142810
bmpcamry09
Rock Sponsor (Level 1)
New Athens, IL
2025 JLU Sport S 3.6 8AT
Those aren’t trouble codes. Those are the generic OBD readings that usually display when your scan tool isn’t compatible. Sometimes a bypass cable or SGW cable is required to read codes on these with a generic tool. Did you click enter after highlighting the 7E8 engine?
MattyAces
Matty
New Jersey
2021 JLU Willys
I did and it just says no info stored
bmpcamry09
New Athens, IL
Then you probably don’t have codes. Pretty rare that a no start throws codes right away. Start with basics. If no power/no crank start at the battery and work your way out. If it cranks but no start, start with spark and fuel and do the same.
MattyAces
Matty
New Jersey
2021 JLU Willys
Yeah I checked the battery and it's showing green....jumped it and it started and stayed running after the jumper was removed which makes me think the alternator is working but maybe not strong enough to charge the battery....well see just towed it too the shop....I'll update when I got info. Thanks for the help
alphawolff
california
2021 JLU
You probably just need a battery(s). If you only have one, it's two minutes to replace it.
