Help please
popstatwo
Tim
2020 Jeep Wrangler
Good morning,
I recently put wheels and tires on my wife's jl and I had to remove a piece from behind the fog light assembly because of rubbing. Now that I have done that, the back of the fog light and the wires are all exposed. Is there a flush piece that I can buy to cover up the area that is exposed? Thank you for any help.
Jeep Wrangler JL Help please IMG_0304
jludave
The Isle of Long
IT Manager
Most will trim the pieces removed to make a backing plate. If you do a search, there are numerous threads on how to do it. If not, there is no danger to leaving the bumper and wiring exposed. I've been running that way for over a year without issue.
popstatwo
Tim
2020 Jeep Wrangler
No issues with rain or anything getting into the fog light housing? And the phrase to look up is "backing plate"?
jludave
The Isle of Long
IT Manager
VooDoo1
Don
Sacramento, CA
2018 JL Sport S, 2007 FJ Cruiser
Trim the pieces you removed and replace to cover the rear of the fog lights. Here is what I did.
Jeep Wrangler JL Help please bumper
Yondu_JLU
Suwanee, GA
2020 Jeep Wrangler Sport S
Good morning,
When I had my stock bumper on, I decided to trim the close out panels. Used a bright marker to follow the lines/ outline so that it would sit nice and flush with the bumper. Used a Dremel to trim them and then sanded it gently to smooth out the lines.
You should be fine either way.....I'm running the steel bumper now and it does not have a close-out panel option. Been just fine.
Boatbuilder88
New Jersey
'19 Wrangler JL
F-16 Engineer (retired)
Trim off the offending bumper extensions with a dremel to create your new "covers." Smooth any rough edges with sandpaper.
Jeep Wrangler JL Help please 20190218_174737
