Heated steering wheel too hot
Laz
Tom
New Hampshire
2018 JLUS
Most of the time, mine is just warm enough and other times almost untouchable. Ive had mine go off by itself on high limit before.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
I simply put on a good pair of gloves when it gets too hot, allows me to keep my hands warm without burning myself!
On a more serious note, other cars that I have had would cycle on and off so you don't get too hot, the jeep does seem to get hotter than most. even the heated seats (cloth) get crazy hot pretty quickly.
Now back to that recipe that uses the heated steering wheel to cook bacon...
maguro
Ken
Canadian Rockies
Punk'n JLUR
The easy solution is to drive while wearing a pair of oven mitts.
But seriously, the heated steering wheel is one feature I can't live without. If only the shift knob were heated too. ;)
swish77
Aaron
CT
2021 Wrangler Sport S 2-Door
Bumping this thread with a related question .... Just picked up my 2021 Wrangler Sport S and I find that the heated steering wheel heats up very quickly, gets nice and hot, but then cools down significantly after about 10 minutes or so. Does it heat back up to "hot" again after a certain amount of time, or is it normal for it to stay just luke warm after the initial hot start-up?
I guess I could always turn it off and then turn it back on to get it into "hot" mode again, assuming that would work.
CarbonSteel
I find that after initial warm up it heats by "zone" and the heated parts rotate. See if another part of the wheel is being heated when you find one part is not.
swish77
Aaron
CT
I'll double-check, but it seems that the entire steering wheel cools down and stays lukewarm, but not "hot" in any one section and/or on any rotation of heat. Only had the Jeep two days, so I'll run some tests. Thanks.
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
I've had several vehicles with heated steering wheels, with one of them being a Grand Cherokee, and I don't feel any different with the JL as with the others. They will heat your hands up while wearing gloves. I don't think they are there to constantly heat up non gloved hands. Your car heating up while driving should take care of non covered cold hands.
rotlex
Whitehall PA
2020 Jeep Wrangler Unlimited
I have the opposite problem. 2020 JLU. It gets Luke warm at best.
Now the seats - whew, can probably get a burn off of them, lol. Anyway to test\check if it is in fact working properly? The wheel that is.
Now the heated grips on my Harley - you can literally fry bacon on them if you crank them to max, lol.
swish77
Aaron
CT
Yeah, I guess it depends on the manufacturer. I owned a 2015 BMW X1 for a couple of years and that heated steering got hot AND stayed hot. I guess the Jeep steering wheel is supposed to give you a quick jolt of heat in the cold, but is not meant to maintain the heat at a high level.
Sboden
Kansas City
Temperature is tough anyways because people have very different ideas about hot and cold due to various reasons.
