Madtom
Thanks. If the used harness I ordered is missing these parts/connectors I may need to get a couple to make a cable from the heated seats and steering wheel controller over to the canbus.@Madtom yes that is the can connector that goes in the white block under the glovebox. It connects to the control module under the steering wheel. I finally got the seat pads and jumper harness for under the seats and put them in last weekend, they are a great addition.
Gregj
Did you use JSCAN or dealer flashing the codes(JPM,NHS) to add the seat heat function?
I'm probably gonna add the seat heat first as I am still looking for a used Rubicon heated wheel that isn't over 300$.
Currently waiting for the wiring to get here to start all of this. My first military job was aircraft electrician way back in the 80s so harnesses are easy, just takes patience.
