Headlights/Fog lights
Ashley
Palm Springs, CA
2018 wrangler JL unlimited sport
Okay, so I have a sport and want to put LED lights into the headlights and fog lights. I know some LED’s do not give off great light. What are some of your recommendations for either just the build or the whole housing unit. I am looking for something reasonably priced.
Take your pick. I have had SV.4 bulbs in my halogen housings for about 2 years now. I wouldn't change a thing. Never get flashed, lots of light. Be careful about aiming. There's a fine balance between you seeing better and blinding oncoming traffic.
E.O.D.
Adam
Georgia
2018 JLUS
I haven't changed my foglights yet, but I went with Oracle Oculus a couple years ago.
Oracle Oculus
The cutoff on the dim setting is pretty sharp (when on low beam, the lights don't have much light "pollution" above the hood of your Jeep, its a pretty sharp line of where the light emission actually doesn't go any higher.)
On high beams, its plenty of light above hood level.
Both low beam and high beam are stupid bright.
Ashley.ennis27
Ashley
Palm Springs, CA
Very good video, thank you!
MOOG5050
Ny
Rubicon XR
Sv-4 headlight bulbs and oracle fog light bulbs. Together they are awesome and much cheaper than a complete replacement. I agree with the comment on aiming. I lowered mine a fair amount from stock aim and still great visibility but no one offended.
I also used oculus bulbs for drls.
Can you point me to the Oculus DRL bulbs?
MOOG5050
Ny
Rubicon XR
mgarciaknight
MG
TerraX
2021 JLU80
Heimkehr
Pennsylvania
2021 JLU 2.0T
Several good options are available. I decided to use these well-regarded H13 LEDs, to good effect. Fan and fanless versions are available (i.e., active or passing cooling.) Yes, post-facto aiming should absolutely be fine-tuned to avoid dazzling oncoming drivers.
This is what I used to replace the halogen fog lights.
John1225
Los Angeles
2016 Jeep Wrangler
I replaced my headlight bulbs with these Auxito H13 LED bulbs, the light output is vastly improved over halogen being both whiter and with a noticeably longer reach. Even with that, the light pattern is great; one can see it chops off at the top nicely when behind another car and nobody oncoming has yet seemed annoyed. High beam is deceptive. It SEEMS like it's not as bright but it is and it really does something and illuminates far and high which the stock halogen bulbs do not.
Jeep Wrangler JL Headlights/Fog lights 1683254937217
Maverick909
I.E.
beamtech have been on my jeep for 3 years without issues. Really like them and they do not though the headlight bulb out code.
