Hardtop Storage for JLUR
thejill
Jill
Massachusetts
2020 JLUR
I am looking to swap out my hardtop for the softtop in these next few weeks and I was looking for a storage cart of some type that will hold the top and the freedom panels. Has anyone seen or have anything like this? I have door hangers already.
I have seen the lifttop pro but I don't necessarily need help getting the top off/on.
Thanks!
AirportDave
Denver, CO
2022 JLUXR, 2018 GC Trailhawk Hemi
Aeronautics Professional
I can't recommend the Toplift Pro enough. I don't have enough overhead space in my garage to hang my hardtop, so the TopLift was the perfect solution for storage for me, as I can drive my JLR right under the top, and I just hang the Freedom panels in their bag on the wall. It also makes swapping between my OEM soft top pretty quick and easy, although fitting the softtop back into the rollbar brackets is still a two person job. And you can hang the folded up softtop and frames from the TopLift, keeping that out of the way when the hardtop is on. It was not inexpensive, but for me, worth every penny.
Jeep Wrangler JL Hardtop Storage for JLUR IMG_9094
Jeep Wrangler JL Hardtop Storage for JLUR IMG_8614
Granizle
J.P.
British Columbia, Canada
2018 Wrangler Sahara JL, 2017 Wrangler Sport JK, 2007 Wrangler Sahara JK
Cost me maybe $40 and is strong enough to add your panels on top.
Jeep Wrangler JL Hardtop Storage for JLUR 28B03485-2022-4176-AB42-4E0543CCEEF1
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
I just helped a friend assemble his TLP and use it for the 1st time. Do you find it requires a bit of strength to lift the top? I thought you would use the handle as a hand grip, but you more of lay arms over it and use my body to lift the top.
Also to put the top back down, you release the "brake", and all the weight transfers back to the user, it was a shock accepting that weight, maybe I just expected more of a mechanical advantage than the lift provided. In fact the 1st time we tried it without the jeep under it, it dropped low and sort of crushed my wrist.
Overall it works, and its a good solution, just wonder if we have something wrong, the effort to raise is high, and its hard to control the drop gracefully.
Thanks!
AirportDave
Denver, CO
I don't find it bad at all, but you do need to be ready for the weight transfer- I'm 6'2" and about 200. If you are short and/or light, I would expect it would be worthwhile to have someone standing by to assist.. I have the 2 door top with crossbars, cargo basket and awning, so I'm guessing my 2 door top weights a little more than a bare 4 door top.
MacombRoger
Roger
SE Michigan
Solution Architect
Thanks. I am a big guy, so I got used to it, but he is shorter guy. He can do it, its just more of a shock to the system than the videos seems to show. :)
thejill
thejill
Jill
Massachusetts
2020 JLUR
@thejill what did you end up going with - I'm in the same boat as you! Thanks
I ended up going with the Top Lift Pro. I was able to manage it on my own, but I will be honest, I was super nervous using it the first time, alone. But I didn't drop it and it hasn't fallen off yet! haha
thejill
thejill
Jill
Massachusetts
2020 JLUR
I agree! It took more effort than the video leads you to believe! I managed it on my own, alone, but I was NERVOUS!!
