pfjeepchick0205
Thank you for explaining very well. I am going to give this a try and hope the wind noise goes away.It's kinda self explainatory, but look at the middle latches on the freedom tops (mirror area) , the clip they latch to can be adjusted down (slotted)with a Torx screwdriver. The trim panel "pop"s down for easy access. A little movement goes a LONG way.
The windshield hinges are accessed by folding windshield down and loosening the Torx bolts on the windshield side of hinge very slightly. Then move windshield frame up very a tiny bit and tighten bolts. This actually moves the w/shield frame closer to body/seals, just don't over do it. You should feel very slight resistance just as windshield folds back up tight to body. It may take a few times to get the resistance but all it takes it slight contact to seal on the frame.
The freedom top seals are very good quality but cooler weather does make them not very resilent or pliable.
Never put anything petroleum based on rubber. They are plenty of rubber safe products out there, some silicone sparays are safe.
