Grimm Offroad Mount + ARB Compressor Install
CarbonSteel
The installation took about 3.5 hours from start to finish. I did not rush, and everything went very smoothly. Make sure that you get new fender clips--you will need them. Nine out of ten of mine broke and I since I will be replacing both batteries soon and the other fender will have to be removed as well, I picked up a forty pack of them on ebay.
The only thing that I forgot to do was install the "keeper" on the main power wiring, so make a note to do that—BEFORE you re-install the fender because you will not be able to reach it afterwards. I do not think mine will disconnect, but if it does, it will require pulling the fender again. I also elected not to remove the driver’s front tire and I am good with that decision. Removing it does not make the installation any easier because there is plenty of room to do what is needed.
Tools/Parts Needed:
  • 10mm Combination Wrench
  • 10mm Socket and Ratchet
  • 12mm Socket and Ratchet
  • 13mm Combination Wrench
  • 13mm Socket and Ratchet
  • 15mm Combination Wrench
  • Zip Ties
  • PET Braided Wire Covering (optional)
  • Heat Shrink Tubing (optional)
  • Heat Shrink 8 Gauge 5/16" Ring Terminals
  • Teflon Tape
  • Blue Loctite
  • Di-Electric Grease
  • Fender Clips (it takes 10 per fender, but you may get lucky on some) (https://www.ebay.com/itm/293957627093)
Step 1 - Mount the air compressor into the Grimm mount. Be sure to use blue loctite on the screws to prevent loosening in the future.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 01 - Bottom of ARB in Grimm Mount
Step 2 - Install the air intake ferrules as well as the high-pressure outlet connection on the compressor. I wrapped the intake ferrules with electrical tape to prevent dirt from entering during the installation and lifted the protective plastic wrap and used it to cover the high-pressure outlet as well.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 02 - Top of ARB in Grimm Mount
Step 3 - Assemble the air chuck and air inlet filters onto the Grimm mounting plate. Be sure not to overtighten ferrules on the plastic air filters as they will strip or break.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 03 - Grimm Switch and Chuck Mount
Step 4 - (not really required) I installed PET braided tubing and applied heat shrink tubing on the ends to prevent fraying to give an extra layer of protection.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 04 - ARB Intake Hoses
Step 5 – Remove the Christmas tree retainer and the five 10mm bolts from the fender.
Step 6 – Pull on the fender to detach it from the body. It takes some force and you should start on one end or the other. DO NOT pull it too far away from the body because there is a wiring harness for the turn signals/park lights that has to be disconnected.
Step 7 - Remove the two 10mm nuts and the wiring bracket from the firewall and detach the wiring from it. There is a "Christmas tree" connector on the wiring that also has to be disconnected from the fender. Cut the original zip tie from the gray post connector and use a new one to re-attach the wiring to it. I also added zip ties in two other locations to secure the wiring but it is not necessary. Add the Grimm Spacer to the studs on the firewall. Next, remove the 13mm nut from the lower master brake cylinder stud.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 05 - Wiring Re-routed and Grimm Space in Place
Step 8 – Mount the compressor onto the two firewall studs and the stud on the master cylinder. Reinstall the 10mm nuts on the firewall. A 10mm combination wrench will be needed to tighten them. Next re-install the 13mm nut onto the master cylinder bracket and tighten.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 06 - Top of Grimm Mount In Plac
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 07 - Fully Mounted
Step 9 – Attach the air intake hoses, the high-pressure stainless braided hose, the ARB power cable, and the Grimm switch cable and route them to their approximate locations. Be sure to use some di-electric grease on the connections to prevent the inevitable corrosion that will happen if left untreated.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 08 - Routing Air Intake Hoses
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 09 - Air Intake Hoses + Power Cables
Step 10 – Mount the Grimm switch and air chuck plate in its location and attach the air intake hoses and the high-pressure stainless steel hose. Pass the Grimm switch wiring through the hole on the plate. Ensure the arrow on the back of the switch is pointing up. The connections used will be the side with the 3 spade connectors. Connect the purple wire to the bottom blade, the red to the center, and the black to the top blade. Snap the switch into place.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 10 - Air Chuck + Switch Plate Mounted
Step 11 – Route the ARB power cables behind the engine over to the battery. I used zip ties to secure the harness to the cowl wiring trough mounts pulling it snug as I tied them. I then crimped on some 8 gauge 5/16” ring terminals to each of the positive wires and applied some red heat shrink tubing to further insulate them.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 11 - Positive Wiring Terminated
Step 12 – Twist the small black wire from the ARB power cable onto the 8 gauge black wire and crimp an 8 gauge 5/16” ring terminal (both wires go into the one ring terminal. I then applied some black heat shrink tubing to further insulate the wire.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 12 - Negative Wiring Terminated
Step 13 – Remove the fuses from the ARB fuse holder and add some di-electric grease to the terminals inside the fuse holder. Reinstall the fuses ensuring they are firmly seated. Replace the weather resistant caps on the fuse holder ensuring they are properly seated.
Step 14 - Remove one of the nuts on the positive terminal block on the battery, attach the red wires. Replace the nut and tighten. Repeat this process for the black wire on the negative terminal block. Arrange the wiring and secure as necessary with additional zip ties.
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 13 - Wiring Completed
Step 15 – Test the compressor to ensure it operates properly. Arrange any remaining wiring as needed and secure with zip ties.
Step 16 – Replace all of the broken fender clips on the fender. I found the easiest way to remove them is by breaking off the flat tab on each edge of the clip, then slightly rotating them to remove from the fender. Reinstall new tabs ensure they are fully seated and lie flat against the fender.
Step 17 – Loosely place the fender in its location and re-attach the turn signal/parking light wiring. Make sure the fender cannot fall and test your lights to be sure both are working BEFORE attempting to re-attach the fender. After testing, place the fender in its location and push on it in a straight line towards the passenger side. The lower part of the fender will likely not pop back into place requiring you to push fairly hard on it.
Step 18 – Replace the five 10mm bolts and tighten. Next replace the Christmas tree retainer.
Step 19 – Double check your work and clean-up your work area
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 14 - Final Product
Step 20 – Go wheeling knowing that you can now air up and down as needed on the trail.
Thanks @Grimm OffRoad!
mdkautzman
Centralia, WA
2021 Jeep Gladiator
I applied adhesive backed heat resistant material to the outside of the shield for added protection. Also don't forget to get the dust cover for your air hose reciever.
Nice write up and it's a FUN project. Did both my JT and JL.
CarbonSteel
CarbonSteel
Thanks; yep, I meant to order one from Grimm when I ordered the mount. I ordered two today.
BeachPilot74
Garrett
Colorado Springs
2022 JLUR XR, 2013 F-F150
Airline Pilot
Isn’t this a bad location for water intrusion? Any kind of deep water crossing and this thing is submerged and toast.
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Come on dude. Are you really forging water above your fender line? Your air box will be under water and the least of your worries is your air compressor. LOL
BeachPilot74
Garrett
Colorado Springs
Airline Pilot
Maybe I’m looking at this wrong, isn’t this under the inner fender liner?
shooting4625
Colin
Coming soon 2023 2door wrangler Rubicon
It’s a great set up, mine still looks clean under there and I have been in some serious mud that I have had to clean
Only thing I did differently is that I did not want to open the hood, so I run a high pressure line to my rear bumper, just open my tailgate attach my 4way air up turn on the compressor from Aux switch 3 and I can watch the air pressure come up on the dash
I used an ARB coupling for the connection
Jeep Wrangler JL Grimm Offroad Mount + ARB Compressor Install 9C95DB43-E402-4598-845B-BB2587AE10D2
Buzz11
Buzz
Colorado, USA
2019 Wrangler JLR, 2001 Wrangler TJ Sport
Sorry to revive an old thread. I'm wondering if there is any disadvantage to taking out the inner fender instead of the entire fender?
Seems like removing the plastic rivets is less likely to break things and eaiser to reinstall than removing the fender and all those clips.
