Grill swaps variations Pre-2024
Jmos4
Jim
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Picked up a grill from a JT 2021, my JLUR is a 2022 both have the silver inserts.
Question on anyone who has done a similar swap, did you notice the inserts/silver inserts and shell is different.
My 22 had clips in different places and the silver part covers the grill differently.
Doner:
Jeep Wrangler JL Grill swaps variations Pre-2024 Screenshot_20260310_114914_Facebook
Swapped center silver section and grill inserts:
Jeep Wrangler JL Grill swaps variations Pre-2024 20260310_173854
Notice how the lower coverage?
Is there different inserts or was it changed for the JT?
Regards,
Jim
The Fixer
North Jersey
Teacher
It was changed for the JT to allow more airflow, from what I've read. I like the difference; subtle enough to almost not see it.
Edit: I knew about the larger honeycomb sections, as I put them on my JL. I didn't realize the surrounds were different.
2nd 392
Ca
Hi,
Doner:
Regards,
Jim
Yes the JT, diesel I think, and 392 have bigger openings.
Jmos4
Jmos4
Jim
Hi again,
Belive both were 3.6, so still wondering why the difference
Regards,
Jim
2nd 392
Ca
Hi again,
Regards,
Jim
More air flow as mentioned for needed better cooling on the PU, 392,, and diesel.
Riptide_JLU
Shawn
Norcal
2021 Jeep Wrangler JLU Sport S 3.6L Auto
Data Analyst
I’m going to believe one is a grille from a Sport vs a Rubicon or possibly Mojave. The Sport grille outer edge will all be connected where the Rubicon grille’s come apart.
kah.mun.rah
Merenkahre Jr.
Duat
Does it even matter since an angry grille is the only grille you will ever want, and ever need?
Jeep Wrangler JL Grill swaps variations Pre-2024 1773258599713-g5
Jmos4
Jmos4
Jim
Hi,
Both have silver inserts between the grill inserts and outer shell. So looks wise no real difference, see above images, other than openings in the silver inserts and internal mounting configuration.
Regards,
Jim
