Getting wires through the firewall
xsaltlifex
Eric
Tampa bay area
2021 black on black 6 spd 2 door
Hey jeepers' was wondering what method or route you took to chase wires through the fire wall for switches for light bars and such. Any suggestions would be greatly appreciated. Thanks in advance..
jludave
The Isle of Long
IT Manager
If you have an automatic, there’s a plastic body plug in the firewall just below the brake booster. Pull the plug drill a hole in it, put it back, run your wires and seal with RTV and you’re good to go.
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
If you have an automatic, there’s plastics plug in the firewall just below the brake booster. Pull the plug drill a hole in it, put it back, run your wires and seal with RTV and you’re good to go.
That's what I did. I ran a 0 gauge wire through the plug and popped the plug back in place.
xsaltlifex
xsaltlifex
Eric
Tampa bay area
Thanks guys. I have a six speed but I still have some sort of grommet under the brake booster. Will investigate further after work.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
1996cc posted this pic along with that article this pic shows the nipple to use on the grommet for pass through on passenger side. read the article to save yourself a lot of trouble.9 do not go through the red highlighted area! you can see the nipple to use right next to it)
Kripas
Kripas
San Leandro California
Jeep Wrangler JLU
DO NOT RUN WIRE ON PASSENGER SIDE FIREWALL, IT WILL COST YOU $2500. I did it on mine and accidentally pulled some sensitive wire inside while running cables and cost me $2500 just to repair it. It not worth it.
