Don’t use passenger side grommet to get wires through firewall!
1996cc
Oregon
21 JLUR 392
I used the grommet based on some threads I found here. Now at least 1 of my AUX switches doesn’t work anymore. After wiring in my Search & Rescue radio, I lost my lights wired to the AUX 2 switch. I decided to stick my camera scope inside the grommet to take a peak. I assumed that the factory would pass the wires straight through, even wrapped in the fabric tape they have on the outside - that IS NOT the case. It is like spaghetti in there!! Now I’m pretty sure that I cut a wire (hopefully only 1) while poking through it with a sharp screwdriver :(
Here is the grommet with my coax and power/ground wires going through:
And inside the grommet:
I hope this saves someone else from this problem. This is going to be a nightmare to try and fix! I’m open to any suggestions.
1996cc
1996cc
Oregon
21 JLUR 392
I dove into it today. Didn’t sleep well last night knowing this was coming. It took me about 6 hours to yank both batteries, power distribution center, airbox, etc. to get access to the grommet to fix my epic mistake. The install video from Genesis for their dual battery system was helpful.
In the process of getting to the grommet:
The wires I ran that caused this problem:
What it looks like inside the grommet. On the bottom left you can see the 2 wires I cut (which happened to be the wires for the AUX 2 & 4 switches). They are both brown (with different tracers), hiding behind each other.
Rico1111
Rico
RI
2018 Rubicon 2 door JL
Wow what a nightmare hope you get it all sorted!!! Definitely not for the squeamish!
Kyanche
Daaaaaaaaaamn!
I’m glad I ran my power step wires through the clutch hole! Sadly I lost the plastic cover and I’ve been meaning to buy a grommet to cover it up hhaha
1996cc
1996cc
Oregon
21 JLUR 392
I did. Forgot to mention that at the end, got it all done and put back together. The best part - the Jeep started right up, and my Aux 2 & 4 switches work again!!!!
Normally I don’t drink much at all, and never feel the need to “take the edge off.” I had a couple tonight.
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
I haven't needed to run wires through there yet, so I haven't looked into it. Thank you for this photo. There is the perfect spot to run wires through the grommet. So perfect, that it looks like it was planned for accessory installations. See thick red circle. You can see the back side of that in one of your photos as well.
MarkY3130
Denver
2019 JLUR
Nice observation. I will give it a try hopefully this weekend with a front camera.
1996cc
1996cc
Oregon
21 JLUR 392
You can’t get to that spot without pulling both batteries and the power distribution center. See the first pic of the whole engine bay with everything torn apart. You can see the grommet in that pic too. But, if you look at the backside of the grommet in another pic, I think you are correct, it looks like a female hole on the inside! That also appears to provide a safe channel/tube above the rats nest of loose wires. Good catch - it is definitely NOT something you can see without digging in as far as I did...
Welp, looks like I still have another hole available now on the passenger side if I need to run more wires!! :)
Chipe
Chip
CT
Silverado
So it's the perfect spot to run wires through but you can't get to it with out all that disassembly?
1996cc
1996cc
Oregon
21 JLUR 392
I think you’ll be able to get to it, since you know it’s there. You can feel your way in from the inside and just poke it out and then fish it from under the batteries, etc... I certainly didn’t see it beforehand.
LostWoods
Mesa, AZ
2020 Gladaitor Sport S
Bringing this one back from the dead because I managed to get a 10.3 mm thick 4 awg wire through that nipple on the passenger grommet in my JT. A quick snip between the lip and the bulb on the end and you get a hollow rubber tube.
For 4 or 6 awg, you definitely need to be fishing interior to exterior and be sure to lube the cable. I don't think you'll get enough strength on the pull without pulling the battery or maybe by soldering a smaller fish wire (like a 12 awg) to the end of the cable to reduce diameter. I fished with a 12 awg taped to the 4 awg and it went with a lot of effort.
For 8 awg or something like the aux switch harness, I think you can fish exterior to interior and just pull it back out to fix the inverted nipple on the grommet. A ziptie around it should seal against the wire but my 4/6 awg power cables were plenty fat for it to seal on its own.
If you're going to do this without pulling the battery, you're going to need small, dexterous hands. You can get a little space by removing the lower tray for the second battery as well - just 3 screws from the bottom. In any case it's a tight fit.
TJJL19
TJ
2019 Jeep Unlimited Sport
I was looking over the internet, for a way to run a power wire, for the Kicker 10in power sub.
I ran accross this on youtube
Look like it will work,what do you think?
  • Like
Reactions: mag
MarkY3130
Denver
2019 JLUR
Isn’t that where the clutch would be if you had a manual? For automatics it’s a no brainer to use that hole. Those of us with a stick aren’t so fortunate when it comes to firewall penetrations.
TJJL19
TJ
never thought of that for manual,I have an automatic. I got to admit that my JKU was a lot easier to add a amp and speakers.
tonygiotta
Tony
Turlock, CA
'18 Firecracker Red JLUR
Fire Captain
Yep, 6 gauge here. With thick insulation, and wire loom on the outside. Definitely was not easy to pull through. Definitely couldn't have done it without the battery removed. A smaller wire could be done with the battery in place for sure, but be prepared to play contortionist while you’re trying to locate that hole on the interior side.
Jeep Wrangler JL Don’t use passenger side grommet to get wires through firewall! 603C8704-86C2-4693-94AA-F6328CD39EDC
