Gear Swap
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Transmission in neutral, but transfer case in 4H with front tires on the ground. Derp.
I was only asking because, I watched A LOT of videos on gear swaps and you should be able to spin the tires or drive shaft by hand in neutral provided the tires are off the ground.......LOL
Some Random Guy
Some Random Guy
Washington
Comptroller
I was only asking because, I watched A LOT of videos on gear swaps and you should be able to spin the tires or drive shaft by hand in neutral........LOL
I was terrified my pinion was loose and the pressure from the driveshaft had pushed it into the ring gear, zero’ing out backlash and binding it!
Some Random Guy
Some Random Guy
Washington
Comptroller
Dead quiet on the way to work. A few more sub60 runs and then I’ll try it on the interstate. I don’t remember the Jeep being so quiet before. I can hear every time my socket rolls in the storage cubby.
Some Random Guy
Some Random Guy
Washington
Comptroller
Well, pinion seal went today.
In good news, I did get a refund check for the first 2 failures. Scheduling with a shop now, clearly beyond my capabilities. Thanks for all the help, I now know my limits.
word302
Oregon
JLU
You probably just lost the little spring of the inside of the seal. I usually pack them with grease to keep them in place during install. I know you’re over it but that’sa pretty common occurrence.
Some Random Guy
Some Random Guy
Washington
Comptroller
I didn’t know there was a spring. Was it supposed to come off the old pinion? If so, there wasn’t one when Yukon was done with it. I don’t remember seeing one on either of the new seals.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
You absolutely have to line the outside of the seal with RTV. If you rely on the RTV that comes on the seal, they will nearly always leak.
Some Random Guy
Some Random Guy
Washington
Comptroller
I did, I used gray spread overtop of the red stuff.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Then the only other thing that could really happen, is you accidently tap the seal out of place during the installation of the pinion. As you're hammering the pinion through the tail bearing, the tail bearing will slowly tap the seal out. If you don't catch that, it'll leak. This happens to a lot guys that take the pinion out more than once. Don't take the Jeep to someone to fix the seal. It's super easy to do, especially now that the pinion is set and through the tail bearing. Just don't over-torque the sleeve putting the flange back on and you'll be golden.
word302
Oregon
JLU
It’s a small metal coil that keeps the inside sealing surface tight to the pinion. It’s less than 1/8” in diameter. Not really a spring, but spring like.
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Just like @word302 mentioned, there's almost always a spring on any seal sealing a rotating part inside a rubber seal. These springs are found in a ton of applications. If this is missing or damaged, you would need to replace the seal.
Jeep Wrangler JL Gear Swap 1644447669827
Some Random Guy
Some Random Guy
Washington
Comptroller
I’m dubious, but for you I’ll try.
To get the flange on I had to use a pin to tap the tail bearing down the pinion. So I’m fairly confident I didn’t knock the seal out since everything was seated and not being hammered around.
Baba Yaga
NJ
www.youtube.com
Retired LEO
The pinion seal was leaking after 600 miles on my regear. I followed a video and marked the nut and flange and I made sure to put the flange back the same location it came off. Then I lined the mark on the nut making sure to not go over. It seemed to work.
You should be able to pick up one at the parts dept. The Mopar part # is 68401310AA.
I purchase a pinion dial torque gauge because I'll soon be replacing the flange to a CV joint one when I get a 1350 axle.
Some Random Guy
Some Random Guy
Washington
Comptroller
Seal is fully pressed in. I have to remove it to check for the spring, right?
Also, if I added a bit if extra oil would it come out like this? I think I got an extra 1/4 to 1/2 a pint.
Jeep Wrangler JL Gear Swap E50EAF84-071B-4CF6-8353-452C159163F1
Some Random Guy
Some Random Guy
Washington
Comptroller
AND, I'm an idiot. I just realized now I have to drain my diff and remove my carrier to get my flange back on. It has taken a hammer with every pinion it's encountered.
