Fuses for Aux switches
GWM4Tennis
George
Maryland
Jeep Wrangler Unlimited JL
I had to get new fuses and relays after installing the Aux switches and none fit in and none are clicking into the fuse box. Anyone have Idea about this? Not getting any power after install.
joshua.mcguoirk
Joshua
Philadelphia, PA USA
2018 JLUR, 2018 JLS, 1997 TJ & 2003 KJ
Did you install yourself or dealer install?
If yourself... The dealer needs to flash the computer to tell the system you now have aux switches installed.
melendez69
Marc
Waxhaw NC
...huh?
It sounds like you installed yourself... If so, you'd have to get the dealer to flash unless you can on your own.
GWM4Tennis
GWM4Tennis
George
Maryland
It has been flashed and showing on the Uconnect. I did it myself as far as install
GWM4Tennis
GWM4Tennis
George
Maryland
There were no fuses or relays in the fuse box for the aux locations and the fuses don't sit in the box well they just slip in and out very loosely.
joshua.mcguoirk
Joshua
Jeep Wrangler JL Fuses for Aux switches AuxPowerLocatio
Which fuse block? From my understanding the fuses are independent of a fuse block and is located within the engine compartment along the firewall with the PDC for aux switches next to the coolant reservoir also at the firewall.
GWM4Tennis
GWM4Tennis
George
Maryland
I understand that but the block has relays ans fuses listed as well and I read someone else the dealers had to install a fuse so I added the ones that show for HD ACCY #1 thru #4 — If Equipped10 Amp Red Micro, 15 Amp Blue Micro, also relays K17, 18, 20 and 21. still no power only thing left is to go back and check my connections but the uconnect is flassed and says it showing the switches
melendez69
Marc
Waxhaw NC
...huh?
The block on driver-side near the coolant reservoir is for the relays. I think the OP is at the fuse box by the battery.
Are there female connectors in the fuse slots? I'm sure you know which fuses to use, but there isn't much information to go on.
Where did you ground?
joshua.mcguoirk
Joshua
Do you own a multimeter? If so... start at the beginning.
1. power at battery
2. power at fuses
3. power on hot side of relay
4. power to switches
5. power from switches
6. power at load side of relay
7. power at either internal or external pigtails
GWM4Tennis
GWM4Tennis
George
Maryland
The block on driver-side near the cooloant reservoir is for the relays. I think the OP is at the fuse box by the battery.
Are there female connectors in the fuse slots? I'm sure you know which fuses to use, but there isn't much nformation to go on.
It dose not feel like any thing in the fuse box is catching so do not think so. I pulled out a couple of the other fuses in the box and they catch but not the ones I installed
GWM4Tennis
GWM4Tennis
George
Maryland
Oh... and not to be a wise guy... are they connected to the battery?
Yes the battery connected to the auto on off needs to be checked and I have read a number of post about it blowing when the negative connection next to the battery is disconnected.
GWM4Tennis
GWM4Tennis
George
Maryland
main battery is connected!
GWM4Tennis
GWM4Tennis
George
Maryland
grounded next to battery on the 3rd bolt
melendez69
Marc
Waxhaw NC
...huh?
