Fuse pull to take doors off??
mhenderson23
2014 Cherokee
Just got a 2021 JLU Willys and weather starting to warm up so time for top and doors to come off. My last Wrangler was a '04 TJ and when the doors came off I had to pull a fuse to keep the dome light from coming on. All I've found online about taking the doors off the JLU is unhooking the wiring from each door. Does that take care of dome light? Or is there a fuse I need to pull as well? Thanks in advance!
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
We've never pulled a fuse and I've never noticed the dome light on.
Heimkehr
Pennsylvania
2021 JLU 2.0T
Note that the folding lever on the door harness connectors needs to remain in the lowered position when removing and refitting the connector. Only when it's re-seated in the vehicle-side connector should the lever be raised to lock both together.
mrtm1970
Marshall
Orlando, FL
2019 JL Unlimited Rubicon
Mechanical Engineer
Nope... the JL/Us are now designed to automatically know that the doors are off once the door harness connectors are unattached.
ONLY flaw I have found is with having the half doors and when I ride no doors front & Half doors on in the rear (my autistic kids need the full half doors on when I drive with them) and I have to take my key fob and unlock the doors for them to open the rear doors as the jeep still automatically locks the doors once you start driving.
In this configuration:
Jeep Wrangler JL Fuse pull to take doors off?? IMG_0726
mikibenz
Michelle
Wisconsin
1975 CJ-5, 2024 Willys UL, various Cherokees
Computer Geek
The doors are independent of the dome light - try it with the doors on or off: Roll your dash / dome light dimmer switch all the way off (down). I like to call this "spy mode". If you need some light when the doors are off you can just turn the dimmer switch up. Google and find your owners manual pdf (I know they are on the mopar site) and review if you aren't sure what I am talking about.
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
zouch
Berkeley, CA
XJ, JLUWD
i'd never thought about that configuration. i'm surprised that i actually like the way it looks as much as i do!
RatZero
Canada
2024 Willys JLU
Manufacturing @ Stellantis
Like previously mentioned, the system is now designed to sense the doors are removed so some lights and door ajar lights won't trigger.
This is also why it's important to ensure that no pins are bent or broken when plugging/unplugging the doors from the system.
There's a test Jeep out there that uses a new connector that's a cool version of an M29 plug that's much more Jeep Idiot Proof.
Sidewalk
Josh
Riverside, CA
JLR
Even fancier, the stereo time out can be changed with the doors off. Normally the stereo shuts off when you open the doors, but without doors it doesn't know you left. So you can program the radio to stay on (I think) up to 10 minutes from shutting off the engine.
