Functional Limb Risers
azjl#3
North AZ
After going to the local OHVs a few times, my JLU is taking quite a beating from branches. I know most people with limb risers are doing it for cosmetic reasons, but I'm looking for some truly functional risers to get the branches up and over the hood/pillars/windshield. What's out there? I see a few kits out there that drill/rivet to the inner A pillar, but I will have a Maximus-3 roof rack going on in a few weeks and would highly prefer to tie in to that. Thoughts?
Cordless reciprocating saw, no more branches.
kkarnage
2022 392, 2020 JLUR, 2015 JKR
Wanted to say thank you to @BullMoose1776 for putting this together. Just made a set of these myself for my 392 from this list. Way sleeker than anything else out there. Love the minimalist look to them.
Jeep Wrangler JL Functional Limb Risers IMG_6094
Here's the list:
You can choose any brand of Limb Risers you want, and you might be able to start there and make them work. I didn't like the heavy turnbuckles. I just wanted a sheathed wire, so that made it much more complex (and costly) for me to complete.
STEINJAGER: Qty: 1, SJ Part# J0030493, Price Each $50.99, Description: 5 Pack, 1/4-28 x 1/4-28 Stainless Steel Quick Disconnect Cable Ball Joint, SQi250 $50.99
WICKS AIRCRAFT SUPPLY: Stud End; Break Strength Min :2000; Cable Diameter 1 :1/8; Sold By: Each; Thread Size: 1/4-28 $7.00 (x8) (you need 4 but you should Buy 8 in case you miss measure, which is easy to do.) $56
AMAZON: Muzata 165ft Black Vinyl Coated Wire Rope 1/8" Overmolded to 3/16" for 1/8" Black Cable Railing System Stainless Steel Aircraft Cable 7x7 Strand Indoor Outdoor Decking Stair Balustrade DIY WR17 WP1 (165 FEET) $75
AMAZON: Marine Bolt Supply; Stainless Steel Thin Jam Nylon Insert Lock Nuts 1/4-28 (pack of 25) $11.95
AMAZON: BLIKA 10 Ton Hydraulic Crimping Tool and Cable Cutter, Hydraulic Wire Battery Cable Lug Terminal Crimper Crimping Tool with 9 Dies, Wire Swaging Tool for 1/8" to 3/16" Cable Railing Hardware $65
AMAZON:KOLEMO Limb Risers Kit Compatible with for 1997-2021 Jeep Wrangler JK/TJ/JL Through The Jungle Protector Obstacle Eliminate Rope $40
BullMoose1776
Bull
South Texas
Project Manager
They look great!
SlickRickMotoADV
SlickRickMotoADV
Rick
El Sobrante, CA
2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
How have they been working for you? I'm considering picking this project up again, especially since it looks like you have the same roof rack as I do.
Brew211
Peoria, Arizona
2018 JLURM, 2022 392 XR, 2024 F250
Here's the list:
This looks perfect, awesome job!!!
I'm hoping to ask for some help, I'm having a hard time find and search the product from Wicks Aircraft Supply, any chance you can find the link or product number? Thank you.
patternman
George
Phoenix AZ
2019 JLUS, 2014 & 2001 Indian
@Brew211
I haven't done this mod but I believe this is what you're looking for.
MS21259-4RH (shows out of stock)
You would strip the overmold on the portion of cable that inserts into cable end and crimp
with the Wire Swaging Tool.
Brew211
Peoria, Arizona
whitee27
Chris White
Binghamton NY
2020 Jeep JLUR
Here's the list:
What a great job. One question I have is why didn't you go this route from Steinjager? Steinjager sells these https://steinjager.com/shop/Exterio...IY-Cables-49.5-inches-overall-length-J0045635 which can be bought at different lengths. I bought them for my JK and just use a set of mounts similar to what you used "AMAZON:KOLEMO Limb Risers Kit Compatible with for 1997-2021 Jeep Wrangler JK/TJ/JL Through The Jungle Protector Obstacle Eliminate Rope $40". It would save on the extra stuff needed. Or am I missing something? Thanks
